Many thanks.
--- In vantage@yahoogroups.com, "Craig Weiss" <cweiss@...> wrote:
> I am not 100% sure on this, but here is what I think I know:
> 1. Open default.mfgsys file with a text editor(Replace default with
> whichever .mfgsys file is called in the short cut to the particular
> Vantage instance (test,train,etc).
> 2. Look for <helpServer uri="" />. If there is a value, make sure
you
> can map to it from the client, and that it contains the help files
(I
> believe the files would be under .\Help\enu\Vantage), and the user
has
> permissions to open them.
> 3. If there is no value for helpserver uri, look for
<deploymentServer
> uri="\\ServerName\epicor\mfgsys803" />. This value is by default
where
> the help files are stored. Make sure the help files are located in
> \\ServerName\epicor\mfgsys803\Help\enu\Vantage, and that the user
can
> access them. This folder should contain several folders with the
names
> of Vantage modules, along with .htm, .swf, & .jpg files.
> I hope this helps.
> Craig
> --- In vantage@yahoogroups.com, "mintokmint" <mintokmint@> wrote:
> > when i open help from Vantage tool bar.The frame says can't find
the
> > pages.
> > Can anyone help?
> > Many thanks
