Why would materials not backflush?
There were some that were sub-con operations and that made sense to me. But it was a variety of operations that had this issue, not just the sub-con ones, and it wasn't even a majority of the sub-con operations, those were a pretty small fraction of them.
When I get around to it, I'll call in to service and see what they say.
I'm wondering if anyone know of any reasons why job materials set to backflush would not issue when the operation is completed. I have a small percentage (about 1%) of materials on open orders now where the operations are set to backflush, and the operations are complete but the materials didn't issue.
If you know anything about requirements for timing, or amount of operations to be reported at once, or any other reason that you know of that would prevent backflushing, that would be helpful.
Verify in the Job that the Material is tied to the Operation in question.  You will find this on the Job Details --> Materials --> Detail sheet under the Related Operation group.  Verify that the Backflush box is checked.  Also, the material should be listed under the Operation in the tree view under Resources.
Prod Standard / Pieces Per Hour filled in? Qty Per parent correct?
Joshua Giese
Technology Solutions : CTO
Direct Phone:    920.593.8299
Office Phone:    920.437.6400 x342
http://wcibags.com/email/emailFooter4.jpg
Sent: Friday, July 22, 2016 10:22
Subject: [Vantage] Why would materials not backflush?
Yup, these are the the first things that I checked.
No, but we don't use production standards on anything. It's not affecting 99% of the operations.
Yes, I'm finding the error because the quantity issued doesn't match the quantity required in the system. If that was incorrect, I wouldn't be able to find the problems with a query.
Any other ideas?
Was the job received qty complete. Is the backflushed material on the final operation
Joshua Giese
Sent: Friday, July 22, 2016 11:06
Subject: [Vantage] Re: Why would materials not backflush?
Any other ideas?
The job is currently still open. The operation is flagged as complete. The operation is the first operation on the part, but materials are generally required at the first operation so that's the operation they should be required on. That's how everything else that is working is set up and it is how it is suggested it should be from epicor training.
The issue isn't that inventory isn't going on hand (which would have to do with the last operation being complete) this issue is that the material needed for the operation isn't being issued automatically when the operation is reported as complete for these small percentage of operations.
I think for back flushing it will only do it on the final operation doesn’t it?
Joshua Giese
Sent: Friday, July 22, 2016 11:18
Subject: RE: [Vantage] Re: Why would materials not backflush?
No. All of our parts are set to backflush on the first OP and like I said, 99% of them are working fine.
In Part Maintenance > Part > Plants > Detail, is the Backflush box checked?  The setup is plant specific.
Ron Brown
Process Manager
Tank Connection
3609 N. 16th St.
Parsons, KS 67357
Office: 620-423-3010 ext. 158
Email: rbrown@...
NOTICE: This email and any attachments are considered confidential and intended for the addressee only. If you have received this email in error, please notify the sender as soon as possible and delete this email. If you are not the intended addressee, any dissemination, distribution or copying of this message is strictly prohibited by law.
Sent: Friday, July 22, 2016 11:06 AM
Any other ideas?
you can also open job entry then go to job details>materials> details. look in the related operation group box to see if the backflush check box is checked. i think, the part has to be checked backflush under the in part entry before you create the job for it to backflush. i am not sure about this.Â
jeb
On Jul 22, 2016 2:24 PM, "Ron Brown rbrown@... [vantage]" <vantage@yahoogroups.com> wrote:
Â
<div>
  <p>
Â
Â
Ron Brown
Process Manager
Tank Connection
3609 N. 16th St.
Parsons, KS 67357
Email: rbrown@...
Â
Â
        Â
Â
Â
Any other ideas?
</div>
<div style="color:#fff;min-height:0;"></div>
Yes to all of it. Those are the things that I know to check. I even wrote a query to look for parts that are set as backflush on the job, and the operation is complete, but the material is not issued complete.
FYI, that flag sets the default behavior of the part when you get details, but you can control it on the job whether it's set to backflush or not.
If you have ticked and tied everything and are still having a problem, have you tried a support call?
Joshua Giese
Sent: Friday, July 22, 2016 14:17
I see that sometimes on 702A Prog.
Sometimes it is the user un data collecting and then doing it again that messes it up.
They do 5 and back it out to only do 3.
Or they manually issue.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Friday, July 22, 2016 12:22 PM
Joshua Giese
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
Is the material marked as backflushable in the part master?
Sent from Mail for Windows 10
Is the material serialized or lot controlled?
S.C.G.
On Friday, July 22, 2016 4:46 PM, "gclauser@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1271629782yiv5856689263ygrp-text">
  <div></div><div class="ygrps-yiv-1271629782yiv5856689263WordSection1"><div class="ygrps-yiv-1271629782yiv5856689263MsoNormal">Is the material marked as backflushable in the part master? </div><div class="ygrps-yiv-1271629782yiv5856689263MsoNormal"> &nbsp;</div><div class="ygrps-yiv-1271629782yiv5856689263MsoNormal">Sent from <a rel="nofollow" shape="rect" target="_blank" href="https://go.microsoft.com/fwlink/?LinkId=550986">Mail</a> for Windows 10</div><div class="ygrps-yiv-1271629782yiv5856689263MsoNormal"><span style="font-size:12.0pt;"> &nbsp;</span></div></div>
</div>
<div style="color:#fff;min-height:0;"></div></div>
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263 -- #ygrps-yiv-1271629782yiv5856689263ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-mkp #ygrps-yiv-1271629782yiv5856689263hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-mkp #ygrps-yiv-1271629782yiv5856689263ads {
margin-bottom:10px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-mkp .ygrps-yiv-1271629782yiv5856689263ad {
padding:0 0;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-mkp .ygrps-yiv-1271629782yiv5856689263ad p {
margin:0;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-mkp .ygrps-yiv-1271629782yiv5856689263ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-sponsor #ygrps-yiv-1271629782yiv5856689263ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-sponsor #ygrps-yiv-1271629782yiv5856689263ygrp-lc #ygrps-yiv-1271629782yiv5856689263hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-sponsor #ygrps-yiv-1271629782yiv5856689263ygrp-lc .ygrps-yiv-1271629782yiv5856689263ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263activity span {
font-weight:700;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263activity span span {
color:#ff7900;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263activity span .ygrps-yiv-1271629782yiv5856689263underline {
text-decoration:underline;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 .ygrps-yiv-1271629782yiv5856689263attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 .ygrps-yiv-1271629782yiv5856689263attach div a {
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 .ygrps-yiv-1271629782yiv5856689263attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 .ygrps-yiv-1271629782yiv5856689263attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 .ygrps-yiv-1271629782yiv5856689263attach label a {
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 .ygrps-yiv-1271629782yiv5856689263bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 .ygrps-yiv-1271629782yiv5856689263bold a {
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 dd.ygrps-yiv-1271629782yiv5856689263last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 dd.ygrps-yiv-1271629782yiv5856689263last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 dd.ygrps-yiv-1271629782yiv5856689263last p span.ygrps-yiv-1271629782yiv5856689263yshortcuts {
margin-right:0;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 div.ygrps-yiv-1271629782yiv5856689263attach-table div div a {
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 div.ygrps-yiv-1271629782yiv5856689263attach-table {
width:400px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 div.ygrps-yiv-1271629782yiv5856689263file-title a, #ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 div.ygrps-yiv-1271629782yiv5856689263file-title a:active, #ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 div.ygrps-yiv-1271629782yiv5856689263file-title a:hover, #ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 div.ygrps-yiv-1271629782yiv5856689263file-title a:visited {
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 div.ygrps-yiv-1271629782yiv5856689263photo-title a, #ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 div.ygrps-yiv-1271629782yiv5856689263photo-title a:active, #ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 div.ygrps-yiv-1271629782yiv5856689263photo-title a:hover, #ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 div.ygrps-yiv-1271629782yiv5856689263photo-title a:visited {
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 div#ygrps-yiv-1271629782yiv5856689263ygrp-mlmsg #ygrps-yiv-1271629782yiv5856689263ygrp-msg p a span.ygrps-yiv-1271629782yiv5856689263yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 .ygrps-yiv-1271629782yiv5856689263green {
color:#628c2a;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 .ygrps-yiv-1271629782yiv5856689263MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 o {
font-size:0;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263photos div {
float:left;width:72px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263photos div div {
border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263reco-category {
font-size:77%;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263reco-desc {
font-size:77%;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 .ygrps-yiv-1271629782yiv5856689263replbq {
margin:4px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-mlmsg select, #ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 input, #ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-mlmsg pre, #ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 code {
font:115% monospace;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-mlmsg #ygrps-yiv-1271629782yiv5856689263logo {
padding-bottom:10px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-msg p#ygrps-yiv-1271629782yiv5856689263attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-reco #ygrps-yiv-1271629782yiv5856689263reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-sponsor #ygrps-yiv-1271629782yiv5856689263ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-sponsor #ygrps-yiv-1271629782yiv5856689263ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-sponsor #ygrps-yiv-1271629782yiv5856689263ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1271629782 #ygrps-yiv-1271629782yiv5856689263 #ygrps-yiv-1271629782yiv5856689263ygrp-vital ul li:last-child {
border-right:none !important;}
Yes, but as stated, that should be controllable on the job. FWIW Both are checked to backflush.
No it is not. We don't have any lot or serialization control for anything in this company.
I have not because I can't recreate the problem at will. I haven't found any pattern to be able to show them when it happens. My experience so far with support is that if you aren't able to recreate the problem, they don't know what do do about it.
I understand your comments………..have experienced the same feedback and still dealing with similar situations in other areas. However, I have been pleasantly surprised occasionally when I hear that Epicor is familiar with the problem reported since they had already experienced with other customers and have a “Fix” already developed that they can send to us……………..I always wonder why we have to bump into those problems and ask for the “Fix” instead of Epicor automatically relaying them to us…………….that’s another topic of conversation.
It sounds like you have investigated most / all of the possible setup issues. The only one I hadn’t thought of was if the operation that isn’t backflushing is a Subcontract operation. There was a thread on the EUG about that problem this morning. I concur you probably need to submit a ticket………..that’s part of the yearly maintenance fee!
Good Luck!
Ron Brown
Process Manager
Tank Connection
3609 N. 16th St.
Parsons, KS 67357
Email: rbrown@...<mailto:rbrown@...>
[http://www.tankconnection.com/sig/tc.png%5d<http://www.tankconnection.com>
[http://www.tankconnection.com/sig/tcli.png%5d <https://www.linkedin.com/company/tank-connection-affiliate-group?trk=nav_account_sub_nav_company_admin> [http://www.tankconnection.com/sig/tcfb.png%5d <http://facebook.com/tankconnection> [http://www.tankconnection.com/sig/tctw.png%5d <http://twitter.com/TankConnection> [http://www.tankconnection.com/sig/tcyt.png%5d <http://youtube.com/user/TankConnection> [http://www.tankconnection.com/sig/tcgp.png%5d <https://plus.google.com/u/0/+TankConnectionParsons/posts>
Sent: Monday, July 25, 2016 12:41 PM
