Dan, Wayne's solution will work -- the INT() is in fact Truncate(number,x)
where x is # of decimal places; in your case should be zero. This formula
will round down to the next lower quarter hour (15 minutes).
Truncate( PayHours * 4, 0 ) / 4
If you want to round to the nearest 15 minutes use this:
Truncate(( PayHours + .125 ) * 4, 0 ) / 4
Good Luck
Jim Stetter
Sent: Friday, August 11, 2000 10:48 AM
To: vantage@egroups.com
Subject: Re: [Vantage] Wildcard usage in report builder
At 10:36 AM 8/11/2000 , you wrote:
integer(PayHours * 4) / 4
You'll have to check for the proper name of the INT() function in R.B.
-Wayne
Good Luck
Jim Stetter
>to round payhours to the nearest 15 minute increment. How can a wildcardbe
>used in this formula: IIF(PayHours >= 8.0 and PayHours < 8.25,8.0,0) toMultiply by 4, truncate, divide by 4
>replace the 8.0, 9.0, 10., and so on?
-Wayne
