Win 2008 Terminal Server ODBC Issues
Thanks - That seems to have sorted it (and the removal of some bad Office ODBC Files)
--- In vantage@yahoogroups.com, "IT Support" <itsupport@...> wrote:
> You need to install the SQL Native Client driver on the Terminal
> Server...
> Of Rupert
> Sent: Wednesday, September 08, 2010 10:58 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Win 2008 Terminal Server ODBC Issues
> We've just installed a new "Internal" Terminal server (2008) and we've
> had problems with reports that have Odbc connections to them. When
> running a report the username/password dialog will always appear. And
> normal passwords will not work?
> Has anyone had a similar issue?
> Thanks
We've just installed a new "Internal" Terminal server (2008) and we've had problems with reports that have Odbc connections to them. When running a report the username/password dialog will always appear. And normal passwords will not work?
SQL or Progress?
And have you setup the correct 32-bit ODBC connection?
Also, the username and password is NOT the same username and password that
is used to log into Epicor with.
If you are SQL then you should probably add users and grant them Read access
to the DB, if you are progress then try sysprogress/sysprogress or you may
need to setup a username and password through the OpenEdge Data Admin Tools.
Rupert
Sent: Wednesday, September 08, 2010 11:58 AM
Server...
Of Rupert
What is the exact message you are getting? I maybe able to help..
Paul
Sent: Wed, September 8, 2010 11:57:56 AM
Â
work?
