We are running some systems with Win2k Workstations and have found no
problems at all. If you use ODBC, you will need to upgrade if your version
is 3.11 or lower.
Roy Bosworth
Senior Manager IT/MIS
Sent: Monday, July 31, 2000 7:46 AM
To: Vantage One List (E-mail)
Subject: [Vantage] Windows 2000
Just a quick question, is there any problem using Vantage 3.0 with windows
2000?
Michael Newey
Process Planner/System Administrator
Zygo Mould Ltd
Ph: 416-675-6551 Ext: 234
Fax: 416-675-9224
E-mail: michael@...
is 3.11 or lower.
Roy Bosworth
2000?
Michael Newey
Zygo Mould Ltd
Fax: 416-675-9224
E-mail: michael@...
