Windows 7 and CrystalReports
I got the same useless disclaimer from Epicor support. It was a tip from a fellow EUG that helped me out and I'm just passing it on. I'm glad it worked out for you too!
--- In vantage@yahoogroups.com, "abcdefgsaga" <Adam.Gwizdz@...> wrote:
> That was it! Thank you very much.
> I am surprised that this worked because I called Epicor and they said they not support Windows 7, it has to be Windows XP.
> --- In vantage@yahoogroups.com, "saab_barracuda" <chris.clunn@> wrote:
> > Have you patched up to the later version of the Crystal Runtime? File date should be 2008. Here is a direct link to EpicWeb (login required):
> > https://epicweb.epicor.com/Support/VantageVista/Downloads/Vantage803/Crystal%20Reports%20XI%20R2%20.Net%201.1%20Runtime%20(03_05_2008).msi.aspx
> > We were having the same error and this fixed it.
> > Chris Clunn
> > --- In vantage@yahoogroups.com, "abcdefgsaga" <Adam.Gwizdz@> wrote:
> > > Hello Group,
> > > Is anyone using Vantage on Windows 7 Professional 32bit?
> > > I am having an issue with printing some reports like Sales Order.
> > > The message I get is "Error in File C:\Users\user\AppData\Local\Temp\SOForm(5bÂ…}.rpt: The request could not be submitted for background processing."
> > > I am on Vantage 803.305L.
> > > Any help appreciated.
Hello Group,
I am. I vaguely remember this. I believe it was a weird file
permission error on the folder in that location, and do not recall
exactly what I did to fix (probably opened the permission on the
directory).
Also verify you are on the latest supported Crystal patch.
Of abcdefgsaga
Sent: Thursday, September 02, 2010 9:52 AM
Subject: [Vantage] Windows 7 and CrystalReports
Hello Group,
C:\Users\user\AppData\Local\Temp\SOForm(5b...}.rpt: The request could
I am using the same OS, but version 8.3.408b. What version of Crystal
Reports are you using? It probably won't matter but I am curious. This
is most likely a security/permissions issue. If you are using the
Windows Firewall, I would create an exception for Crystal Reports.
Tim Dines
ERP Analyst
Steel Parts Manufacturing, Inc.
801 Berryman Pike
Tipton, IN 46072
765-675-5201
Of abcdefgsaga
Sent: Thursday, September 02, 2010 10:52 AM
Hello Group,
I am on 803.305 L
I changed permissions on a "Temp" folder for everyone as full control and still no luck.
Windows Firewall is off.
> Tim Dines
> ERP Analyst
> 801 Berryman Pike
> Tipton, IN 46072
> 765-675-5201
> Of abcdefgsaga
> Hello Group,
Chris Clunn
> Hello Group,
> Chris Clunn
> > Hello Group,
