As I understand it, the service packs are inclusive so you can go from 602 to 606 directly.
George Hicks
PCI
George Hicks
PCI
--- In vantage@yahoogroups.com, "jgiese1988" <jgiese@...> wrote:
> Now when I re-install, I will also do the upgrade from 604 to 606. The base product I have is 602. Do I need to install 604 again before 606 or can I just go from 602 to 606 then go through the schema updates and all that? Or am I better served installing and getting everything running at 604 then updating to 606?
> --- In vantage@yahoogroups.com, "Ned" <TechnoBabbly@> wrote:
> > Soup to nuts, for the OS, updates, Epicor, and Insite. Assuming you have no
> > other 3rd party applications installed, this can be accomplished in 20 hours
> > on the long side, and 12-14 on the short side.
> > Assuming you did your Epicor, OpenEdge and Insite installations on a
> > secondary drive and not to the default "C:\Program Files" location, Insite
> > and even Epicor shouldn't be that much trouble, if you keep all file paths
> > exactly the same, you can actually just do an basic default installation and
> > then do a file copy of the old directory over the new directory and that
> > should take care of any special settings they did to config files. If you
> > are running the 64-bit version of Epicor 9.05 then you likely have your
> > Insite Appserver on another machine, that can stay the same.
> > Same for Epicor, and it is nice to keep any custom reports etc in the same
> > spots so you don't have to worry about updating the references in menu
> > maintenance either.
> > If you did the original install on the C: drive, then I would take the time
> > and opportunity to make sure it is installed completely on a secondary
> > drive.
> > Insite is pretty good about helping with re-installs, even if you have to
> > pay for it, you are only looking at 30 minutes in most cases if you have the
> > default, base installation completed prior to the call.
> > -----Original Message-----
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> > jgiese1988
> > Sent: Monday, October 17, 2011 7:29 PM
> > Subject: [Vantage] Re: Windows Server 08 Upgrade
> > About how long should something like this take. I know I can install Epicor
> > I did it originally (We are not live yet), but Insite Manifest was installed
> > and setup by a consultant I have no clue how they have it configured. I do
> > have a split install however so all my SQL stuff is on another physical box.
> > I would consider that a small win.
> > > Clean installation of everything, with careful documentation of all
> > > your custom settings etc.
> > > I don't trust upgrading for any operating system at all.
> > > Behalf Of
> > > jgiese1988
> > > Sent: Monday, October 17, 2011 7:12 PM
> > > Subject: [Vantage] Windows Server 08 Upgrade
> > > I will need to upgrade our server 2003 install to server 2008. I have
> > > an enterprise license for 2003 that came with the server, but will not
> > > need that at all. I purchased the cheaper 2008 std license but it
> > > appears I am unable to do a regular upgrade this way. Why is beyond
> > > me, but anyone out there experience the same thing, and have a good
> > > procedure for a full format install of Epicor while maintaining custom app
> > servers etc.
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > > have already linked your email address to a yahoo id to enable access.
> > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > > and Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> > already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
