Keep in mind that even though you run this you do not have to post it to
your general ledger, we run the report and manually post it especially if it
isn't run on a times basis
Shari Loesel
Motovario Corp
Shari Loesel
Motovario Corp
----- Original Message -----
To: "'Vantage One List'" <vantage@egroups.com>
Sent: July 20, 2000 10:02 AM
Subject: [Vantage] WIP Capture & Post
> I have a problem:
> The WIP Capture & Post routine was run month by month for FY 1999 & 2000
> year to date (May 2000)
> The routine captured and posted expense activity to the WIP Capture
accounts
> that are G&A expenses.
> Further, the expenses it posted were so large, it reduced the expense into
a
> negative.
> Has anyone had this experience and what did you do to get your G/L back
into
> balance?
> Thank you
> Daniel A. Nichols
> General Manager
> If any part of this message is unreadable, please contact the above at
> dann@...
> Make new friends, find the old at Classmates.com:
> http://click.egroups.com/1/7075/13/_/411782/_/964101500/
> We no longer allow attachments to files. To access/share Report Files,
> (Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
