WIP Recapture Report
Anyone have problems running the report and getting the message “WIP recapture process has started” in the activity message box in the system monitor. Report just sits there, says it’s active and doesn’t even error out. ( one time I just let it run and it finally popped up after 13hrs…) Just trying to run the REPORT, not trying to run the utility. There’s very few of us that have access to run the WIP recapture process, and no one is running it in the middle of the work day.
FWIW - the Inventory WIP Recon report has to do the same processes as the Capture. Basically it needs to use the posting engine to calculate what GL transactions would be created from the part transactions. It just doesn’t do the posting at the end.
