WIP Report
When running the Work In Process report, I noticed that orders closed in the current month are still appearing, which seems unusual. If the order is closed, shouldn’t it be removed from WIP and no longer appear on the Work In Process report? Could the reason these closed orders are still showing up be because the COS/Capture for January has not been processed yet? Additionally, when running the report, the start date is left blank.
Could this also be contributing to the closed orders still appearing on the report?
It won’t come off the WIP report until WIP is cleared. That happens when you run the capture process.
