Workdays formula in report builder
Remember to scan for non work days in the ProdCal. Those would be
holidays and other non-scheduled work days. You will need to find a way
to work those days out some how.
Charlie Smith
Smith Business Services / 2W Technologies LLC
www.vistaconsultant.com <http://www.vistaconsultant.com/> /
www.2wtech.com <http://www.2wtech.com/>
Of amfabllc
Sent: Monday, January 08, 2007 5:13 PM
Subject: [Vantage] Re: workdays formula in report builder
What's really scary is that I follow you. Years ago I made a chart
of what you are talking about and wrote a few reports from it -
hopefully I still have it somewhere. I just searched and read 9 old
posts, and I must say this looks the most promising. I thought I
probably overlooked the prodcal when I wrote that years ago, but I
guess not. I am on 5.0, is there something prettier to work with to
link to the prodcal in 6.1 or 8.03? Thank you very much for your
help, at least I know what direction to go now.
Ann
"Todd Caughey" <caugheyt@...> wrote:
> I don't have it all worked out but one approach....(certainly not
elegant)
> 1. For the Work Center add up the # of actual work days in the
week:
> Day1 = IIF(WorkWeek[1],1,0)
> Day2 = IIF(WorkWeek[2],1,0)
> etc.... then WokDays = Day1 + Day2 + Day3 etc....thru Day7
> 2. 30-Workdays-Out =
> IIF(WorkDays = 5,Date_rb + 42,
> IIF(WorkDays = 6,Date_rb + 35,
> WorkDays = 7,Date_rb + 30))
> Assuming all work centers work at least 5 days. Premise is (30 /
# workdays) X 7.
> Part not worked out....adjusting for starting day of week which
is probably weekday # (from formula) plus/minus some constant.
Today being a Monday or a Friday might make a difference in the
number of work days.
> Then use the resulting date in the filter. Again, this is "an
approach" not a tested solution.
> ReqDate from Order Release? Then link to job via JobProd table.
> -Todd C.
> -----Original Message-----
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]On
Behalf Of amfabllc
> Sent: Monday, January 08, 2007 2:19 PM
> Subject: [Vantage] workdays formula in report builder
> I need to make a report builder report, in it I need to use '30
days
> from today'. I would really like to use the production calendar in
> Vantage if possible so that once the report is finished, as long
as
> they keep the calendar up to date, the report will be correct.
> I am in the ProdCal table, I understand Sun=1, Mon=2, etc...
> Can someone give me an example of what to use for a filter line
for:
> ReqDate <= 30 workdays from today
> I will also need to link it to the job due to I will need filter
for
> engineered but not release. Any suggestions? Is there something
else
> you guys use? Vantage 5.00.329.
> Thanks,
> Ann
I need to make a report builder report, in it I need to use '30 days
Vantage if possible so that once the report is finished, as long as
Can someone give me an example of what to use for a filter line for:
I will also need to link it to the job due to I will need filter for
engineered but not release. Any suggestions? Is there something else
Ann
I don't have it all worked out but one approach....(certainly not elegant)
1. For the Work Center add up the # of actual work days in the week:
Assuming all work centers work at least 5 days. Premise is (30 / # workdays) X 7.
Part not worked out....adjusting for starting day of week which is probably weekday # (from formula) plus/minus some constant. Today being a Monday or a Friday might make a difference in the number of work days.
Then use the resulting date in the filter. Again, this is "an approach" not a tested solution.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of amfabllc
Ann
Ann
elegant)
week:
# workdays) X 7.
> -Todd C.
Behalf Of amfabllc
days
as
for:
for
else
> Thanks,
> Ann
