Working Days Function
I went looking for a function to pass in a start date and duration and get an end date based on working days from a production calendar. I found some good posts that described the right method, but not necessarily in the current Function format. So I took to ChatGPT and made a working one that I wanted to share.
References: ERP:BO:ProdCal
Signature:
Function Code:
// Step 1: Validate input
if (!StartDate.HasValue)
    throw new ArgumentException("StartDate cannot be null.");
DateTime startDate = StartDate.Value;
string calendar = string.IsNullOrWhiteSpace(CalendarID) ? "Office" : CalendarID;
DateTime currentDate = startDate;
int workDayCount = 0;
EndDate = startDate;
// Step 2: Load all modified (exception) calendar days using GetRows
HashSet<DateTime> modifiedDays = new HashSet<DateTime>();
this.CallService<Erp.Contracts.ProdCalSvcContract>(svc =>
    var ts = new Erp.Tablesets.ProdCalTableset();
    bool morePages;
    svc.GetRows(
        $"CalendarID = '{calendar}'", // whereClause
        "",                           // orderByClause
        "",                           // tableName
        "",                           // fieldList
        "",                           // keyFields
        0,                            // pageSize
        1,                            // absolutePage
        out morePages
   foreach (var row in ts.ProdCalDay)
    if (row.ModifiedDay.HasValue)
        modifiedDays.Add(row.ModifiedDay.Value.Date);
// Step 3: Loop forward until the required number of working days is counted
while (workDayCount < Duration)
    currentDate = currentDate.AddDays(1);
    bool isWorkDay = false;
    svc.IsWorkDay(calendar, currentDate, out isWorkDay);
    // Count if it's a regular workday and not in the modified day list
    if (isWorkDay && !modifiedDays.Contains(currentDate.Date))
        workDayCount++;
// Step 4: Set result
EndDate = currentDate;
Hope this helps someone else out in the future!
Nice. Was thinking about calculating workdays between two dates. This should adapt nicely. Thanks for sharing.
Hello, I may have find an error in this loop :
You are not affecting the value of svc.GetRows to the variable ts :
ts = svc.GetRows(
    $"CalendarID = '{this.calendarID}'", // whereClause
    "",                           // tableName
    "",                           // fieldList
    "",                           // keyFields
    0,                            // pageSize
    1,                            // absolutePage
    out morePages
Or do I overlook something ?
I’m not sure exactly what you’re asking but I do feel like you’re missing something because the function works correctly.
It didn’t take exceptions into its computation.
Is your version accurate in your profile? 2023.2? I was reading a thread on here yesterday about the ProdCalSvc not returning the exceptions correctly. Is A BPM to block Dates that are falling on Specific days e.g Sunday
Thanks I will investigate this
Should be able to try it out directly in the Rest Help/Swagger page. That’s what I did when I was working on this function.
