WS-tester connect error
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> Only thing I can think of is, did you specify the correct port when
> you used the WS-Configuration tool?
> bw
That was it. I changed the port to 8311 for training and it worked.
Rich
> --- In vantage@yahoogroups.com, "richmiller55" <richmiller3@>
> wrote:
> > I am using WS-tester to check that I have turned on the Web services
> > correctly. We are in the process of implementing 800.403C.
> > When I try and invoke the GetRows method of ABCCodeService with the
> > WS-tester I get the error message
> > Error Calling Web Method
> > System.Web/Services.Protocols.SoapException
> > Unable to connect to the AppServer
> > Could not connect to the AppServer General Error:
> > No Connection could be made because the target machine actively
> > refused it (7203)
> > I am guessing that it is some sort of authentication issue? To keep
> > things simple I am running WS-tester on the same machine that the
> > Vantage app and the progress database are running The credentials
> > work to log into the app, manager/manager.
> > Any ideas?
> > Thanks
> > Rich Miller
refused it (7203)
Any ideas?
Rich Miller
bw
--- In vantage@yahoogroups.com, "richmiller55" <richmiller3@...>
> refused it (7203)
> Any ideas?
> Thanks
> Rich Miller
