How do I get XLConnect to load everytime I open Excel? Currently I have to go to the XLConnect tab and Launch it manually.
Excel 2016, XLConnect 9.0
Karen
Karen
Does XL Connect 9 exist? Anyway, you can use two registry files to accomplish this, they are located in a folder called reg5 where your XL Connect instance is installed.
First run the reg file called unregister then run the file called register (not register_ondemand)
Thank You!
That was it.
It took a minute to find the reg5 folder, but once I did, this was the fix.
~;)Karen
