Currently I am trying to address an issue in which an end user reported an issue with a custom SSRS report an Epicor consultant created for us.
Issue:
- User navigates to invoice tracker
- User searches for invoice
- User selects actions>>print
- User selects custom SSRS style
- User selects print preview with a form of XML output
- Custom XML generated does not contain Part # though if reprinted as PDF and not XML part # displays correctly.
Question:
- How is the XML’s output determined is it controlled by a data definition just for the XML?
Information Gathered:
Report Data Definition = “MN_ARForm”
-Tables “InvcDtl, PartLot” in definition that have part_num, do not have the column excluded
Report Styles: “Standard - SSRS, Standard MX - SSRS”
XML Output:
- With standard style selected and print preview of XML I received the two fields in the result set:
TxtPartNum=“233D2590G003”
TxtPartDescription="IML & BACKSPLASH ASM
-With the Standard MX style in the result set I only see the part number in "<Details Textbox15=“233D2590G009/9100002340”
