I am having this exact issue. Have you found anything yet?
Hello Group,
I am having an issue with reports being generated. When I go to print preview any report I get the error message "Could not find a part of the path" followed by the path to the MfgSysData\Reports\username. When I navigate to the path I've put in the System Agent it takes me to where the xml should be (MfgSysData\reports\username), but it is not there. I think that the report is either not generating the xml (system monitor shows no errors and shows the reports as being 'Complete') or it is putting the xml in the wrong place. Does any other settings have to do with the placement of the xml file besides the System Agent? Has anyone else faced an issue similar to this one?
J
