Oh, then the same instruction ...File Save Data with report...
However if you need to set datasource connection to that same xml file keep
in mind that same XML file will disappear from the mfgsysdata\reports(login)
folder if you have Archive Period set to 0 days. You can save that xml file
out to another folder if you just want that same data or pick Archive Period
greater than 0 days.
Blake Clemens
Sent: Thursday, November 12, 2009 10:02 AM
Subject: RE: [Vantage] XML WIP Report
We're on 8. Sorry, I meant the Inventory/WIP Reconciliation Report, not
the WIP Report.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of advantage
Sent: Thursday, November 12, 2009 9:58 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Are you on 9 or 8? WIP report isn't Crystal in 8.
File Save Data with Report....In 9 the xml is supposed to disappear from
the
EpicorData\reports\(login) folder if you have Archive Period set to 0
days
or save the xml file out to another folder or set the Archive Period to
'forever' However, xml files have been staying in that folder for 9; I
think what I recal a bug.
<mailto:vantage%40yahoogroups.com> ] On
Behalf Of
Blake Clemens
Sent: Thursday, November 12, 2009 9:39 AM
If I wanted to view this xml file every day would I have to run through
these same steps every time?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Rob Bucek
Sent: Thursday, November 12, 2009 9:21 AM
Assuming you have crystal version XI open up the report for that data
file go to database, set datasource location, create ne connection,
ado.net (xml), navigate to file location, highlight the node newdataset
in the lower frame, then highlight your server name in the upper screen,
then hit update. You may or may not need to hit the refresh button at
that point..
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg <http://www.dsmfg <http://www.dsmfg.com/> com/> com/>
(Click the logo to view our site) <http://www.dsmfg
com/>
Behalf
Of Blake Clemens
Sent: Thursday, November 12, 2009 7:26 AM
Subject: [Vantage] XML WIP Report
How can I take the .xml file for the WIP report and view it? I don't
want to view the .xml code, rather the actual Vantage report.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Blake Clemens
the WIP Report.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of advantage
the
days
Behalf Of
Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Rob Bucek
that point..
Rob Bucek
FAX: (715)284-4084
com/>
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
