When you get a compile error, it will tell you the error and will open the
vanilla form with all the code behind will be there. Simply open the
customization like normal, click Continue / OK after you get the compile
error and then go to Tools -> Customization. All your code will be there.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Jun 16, 2011 at 2:29 PM, Steve <sljones@...> wrote:
> I was writing some code for a customization and saved it prior to testing
> to see if it would compile. Unfortunately, when I closed and tried to
> reopen, I ran into a compile error. I couldn't see a way to open the
> customization at all in order to correct the code.
> Does anyone know a way to get to the code? It's kept in XXXChunk.Chunk, but
> I don't know what encoding is used for that column in the database.
> Steve
