Carey,
It is kind of confusing and hard to explain but I will try. I combined
Backflushing materials and WIP counting in the same sentence and I shouldn't
have. They are actually two different subjects.
We are able to backflush but to only the primary warehouse set-up in the
plant of the specific part number. Because we do not have AMM we cannot
backflush one part to different warehouses depending on the BOM that it is
in.
An example is we have ABC part which is standard for our Front Shop and Back
Shop. Both shops have their own stocking location that we backflush from.
But without AMM we can only backflush from the Primary warehouse which is
where we buy the material too. It is actually our stockroom and when one of
the shops need the material we transfer it to either Back or Front Shop.
For WIP counting without AMM we cannot stock subassemblies. So when they
are finished we do not see them in inventory. So as of right now we have no
real way to count our finished WIP/Subassemblies. Now we chose in our
implementation to see subs as part of the main job which was probably a
mistake but we had major problems with that in our last system. We thought
that this would be better. Until we have AMM I am leaving things alone till
we see what it helps or hurts.
I hope that clears things up a bit. But from what you wrote I believe I
have my answer. AMM does work and Counting WIP is going to be a pain. But
we will be able to do blank tags and just manually input them. It won't be
a true blind count but it will work.
Thanks for your help
Alan
_____
Carey S
Sent: Thursday, November 23, 2006 3:04 PM
Subject: RE: [Vantage] YE Inventory Tags
Alan,
I do in fact have AMM. I am a little confused about your question. Are you
referring to being able to account for items in WIP? I use muliple
warehouses to have a production warehouse and an inspection warehouse, so
when I generate tags, they are generated and sorted for the items that exist
in both. However, the problem I have with WIP is that the tags that are
account for WIP for subassemblies that are marked as NON-stock have to be
manually created.
Backflishing applies to the relief of inventory as tied to an operation...so
is what you are telling me
something along the lines of counting ITEMS in WIP and not having the
components that have been already flushed as a function of reporting
material under an operation show up in their proper quantities?
C
Behalf Of
Stay up-to-date with your friends through the Windows Live Spaces friends
list.
http://clk.atdmt.
<http://clk.atdmt.com/MSN/go/msnnkwsp0070000001msn/direct/01/?href=http://sp
aces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mk>
com/MSN/go/msnnkwsp0070000001msn/direct/01/?href=http://spaces.live.com/spac
in.
Alan
_____
Carey S
Alan,
manually created.
C
>From: "Alan Jensen" <ajensen@companionsy<mailto:ajensen%40companionsystems.com> stems.com>
>Reply-To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
>To: <vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com>
>Date: Thu, 23 Nov 2006 02:29:07 -0700
>Carey,
>Do you have Advanced Material Management? We have been struggling with
>Backflush and WIP materials. We have been told that if we have AMM we
>would
>be able to count the WIP materials and be able to backflush to multiple
>warehouses. I know this is a bit off the subject but your answer sparked a
>problem we are having. Thanks for your help.
>Kelly,
>And to answer the inventory question we have now done two complete full
>physicals on 8.0 and they have been definite learning experiences each
>time.
>The main thing we have learned is if at all possible you want to have all
>function and I mean all functions done before you prepare for the physical.
>This means invoicing, WIP calculations, inventory transactions everything.
>We had a real hard time tying the numbers when we did not do this for a
>july
>physical. But when we did this for the September inventory we were able to
>tye the numbers much better.
>We will also be doing another full physical the end of December and we are
>planning on having all transactions done before we even start the counting
>or preparation of the inventory. Hope this helps
>Thanks
>Alan Jensen
>Materials Resource Planning Manager
>Companion Systems
>ajensen@companionsy <mailto:ajensen%40companionsystems.com> stems.com
> _____
>From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Behalf Of
>Carey S<http://clk.atdmt.com/MSN/go/msnnkwsp0070000001msn/direct/01/?href=http://sp
>Sent: Wednesday, November 22, 2006 9:56 AM
>Kelly,
>The biggest gotcha I found was that the auto-tag generation was only for
>stock items. Therefore, if there are parts in WIP that are non-stock (sub
>assemblimes) the tags are not created, and will have to be created through
>blank tags in quantities that equal the number of non-stock subassemblies
>that you have in WIP.
>Also, make sure you take the snapshot of current levels so that when you
>enter your counts with the date any transactions between the snapshot and
>data entry are accounted for accurately.
>Carey
> >From: "wendorff1" <kelly.wendorff@ <mailto:kelly.wendorff%40scc-wi.com>
>scc-wi.com>
> >Subject: [Vantage] YE Inventory Tags
> >Date: Wed, 22 Nov 2006 15:24:54 -0000
> >This is the first time we will be using Vantage's Count Entry for YE
> >physical inventory.
> >I've used this system in the past only to zero out our inventory and
> >I've created tags in the practice database to learn the ins and outs.
> > So far everything appears straight forward.
> >Does anyone have any insight to any "gotcha's" that i need to be
> >worried about with this module?
> >Also, I'm looking to get perforated paper with carbon backs for tags
> >(3 tags per sheet) - I think someone mentioned Epicor as a supplier
> >for tags? I'm going to look locally as well.
> >Thanks!
> >Kelly
>__________________________________________________________
>list.
>http://clk.atdmt.
><http://clk.atdmt.
> com/MSN/go/msnnkwsp0070000001msn/direct/01/?href=http://sp<http://spaces.live.com/spac> live.com/spac
>esapi.aspx?wx_action=create&wx_url=/friends.aspx&mk__________________________________________________________
list.
http://clk.atdmt.
