Yellow warning message bar
<!-- #ygrps-yiv-501460835 _filtered #ygrps-yiv-501460835 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-501460835 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-501460835 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-501460835 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} _filtered #ygrps-yiv-501460835 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} #ygrps-yiv-501460835 #ygrps-yiv-501460835 p.ygrps-yiv-501460835MsoNormal, #ygrps-yiv-501460835 li.ygrps-yiv-501460835MsoNormal, #ygrps-yiv-501460835 div.ygrps-yiv-501460835MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-501460835 a:link, #ygrps-yiv-501460835 span.ygrps-yiv-501460835MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-501460835 a:visited, #ygrps-yiv-501460835 span.ygrps-yiv-501460835MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-501460835 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-501460835 code
font-family:“Courier New”;}
#ygrps-yiv-501460835 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-501460835 tt
#ygrps-yiv-501460835 span.ygrps-yiv-501460835HTMLPreformattedChar
font-family:“Consolas”, “serif”;}
#ygrps-yiv-501460835 p.ygrps-yiv-501460835attach, #ygrps-yiv-501460835 li.ygrps-yiv-501460835attach, #ygrps-yiv-501460835 div.ygrps-yiv-501460835attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-501460835 p.ygrps-yiv-501460835bold, #ygrps-yiv-501460835 li.ygrps-yiv-501460835bold, #ygrps-yiv-501460835 div.ygrps-yiv-501460835bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-501460835 p.ygrps-yiv-501460835green, #ygrps-yiv-501460835 li.ygrps-yiv-501460835green, #ygrps-yiv-501460835 div.ygrps-yiv-501460835green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-501460835 p.ygrps-yiv-501460835replbq, #ygrps-yiv-501460835 li.ygrps-yiv-501460835replbq, #ygrps-yiv-501460835 div.ygrps-yiv-501460835replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-501460835 p.ygrps-yiv-501460835ad, #ygrps-yiv-501460835 li.ygrps-yiv-501460835ad, #ygrps-yiv-501460835 div.ygrps-yiv-501460835ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-501460835 p.ygrps-yiv-501460835underline, #ygrps-yiv-501460835 li.ygrps-yiv-501460835underline, #ygrps-yiv-501460835 div.ygrps-yiv-501460835underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-501460835 span.ygrps-yiv-501460835yshortcuts
#ygrps-yiv-501460835 p.ygrps-yiv-501460835ad1, #ygrps-yiv-501460835 li.ygrps-yiv-501460835ad1, #ygrps-yiv-501460835 div.ygrps-yiv-501460835ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-501460835 p.ygrps-yiv-501460835ad2, #ygrps-yiv-501460835 li.ygrps-yiv-501460835ad2, #ygrps-yiv-501460835 div.ygrps-yiv-501460835ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-501460835 p.ygrps-yiv-501460835underline1, #ygrps-yiv-501460835 li.ygrps-yiv-501460835underline1, #ygrps-yiv-501460835 div.ygrps-yiv-501460835underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-501460835 span.ygrps-yiv-501460835yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-501460835 span.ygrps-yiv-501460835yshortcuts2
font-weight:normal;}
#ygrps-yiv-501460835 span.ygrps-yiv-501460835EmailStyle34
font-family:“Calibri”, “sans-serif”;
color:#1F497D;}
#ygrps-yiv-501460835 .ygrps-yiv-501460835MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-501460835 div.ygrps-yiv-501460835WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-501460835 ol
{margin-bottom:0in;}
#ygrps-yiv-501460835 ul
We are getting a yellow warning message bar on the bottom left of the main screen. How do we disable these warning message alerts? Currently it is yellow and indicates ‘Ready’.
Global Alerts are erroring out
On Sep 1, 2015 12:43 PM, "'Chang, Chia' cchang@... [vantage]" <vantage@yahoogroups.com> wrote:
Â
<div>
  <p><div><p class="ygrps-yiv-1850877101MsoNormal"><span style="font-size:11.0pt;color:#1f497d;">We are getting a yellow warning message bar on the bottom left of the main screen.  How do we disable these warning message alerts?  Currently it is yellow and indicates ‘Ready’.<u></u><u></u></span></p></div>
</div>
<div style="color:#fff;min-height:0;"></div>
Check the logs it should tell you what the problem is. Not usually in the same place as the app server logs but maybe in the OEwork directories
Joshua Giese
CIO
Direct:     920.593.8299
IT Dept:   920.437.6400 Ext. 337
Site ID:    27450-E905702A-SQL64
Wisconsin Converting, Inc.
Sent: Tuesday, September 1, 2015 11:55 AM
Subject: RE: [Vantage] Yellow warning message bar
What’s causing these global alerts to error out or if we can disable them from showing the yellow bar?
Sent: Tuesday, September 01, 2015 11:54 AM
To: Vantage
Subject: Re: [Vantage] Yellow warning message bar
Either one will clear the alert, but from my experience the yellow alert bar won't go away until the next time you log in.
Steven G,
On Tuesday, September 1, 2015 1:45 PM, "'Chang, Chia' cchang@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1782512693yiv1488596218ygrp-text">
  <div></div><div class="ygrps-yiv-1782512693yiv1488596218WordSection1"><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">Looked at the global alert error log and found that there was no email recipient for a Buyer.&nbsp; If we delete the global alert in the log, will this remove the yellow warning bar or should we enter an email on the Buyer and resend the alert?</span></div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="font-size:11.0pt;color:#1F497D;"> &nbsp;</span></div><div class="ygrps-yiv-1782512693yiv1488596218yqt6341568502" id="ygrps-yiv-1782512693yiv1488596218yqt66752"><div><div style="border-top:solid #B5C4DF 1.0pt;padding:3.0pt 0in 0in 0in;"><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><b><span style="font-size:10.0pt;">From:</span></b><span style="font-size:10.0pt;"> vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] <br clear="none"><b>Sent:</b> Tuesday, September 01, 2015 11:59 AM<br clear="none"><b>To:</b> vantage@yahoogroups.com<br clear="none"><b>Subject:</b> RE: [Vantage] Yellow warning message bar</span></div></div></div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"> &nbsp;</div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal">&nbsp; </div><div id="ygrps-yiv-1782512693yiv1488596218ygrp-mlmsg"><div id="ygrps-yiv-1782512693yiv1488596218ygrp-msg"><div id="ygrps-yiv-1782512693yiv1488596218ygrp-text"><div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">Check the logs it should tell you what the problem is. Not usually in the same place as the app server logs but maybe in the OEwork directories</span></div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">&nbsp;</span></div><div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><b><span style="font-size:11.0pt;color:#1F497D;">Joshua Giese</span></b></div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">CIO</span></div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">&nbsp;</span></div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="font-size:8.0pt;color:#1F497D;">Direct:</span><span style="font-size:11.0pt;color:#1F497D;"> &nbsp;&nbsp;&nbsp; </span><span style="font-size:8.0pt;color:#1F497D;">920.593.8299</span></div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="font-size:8.0pt;color:#1F497D;">IT Dept:</span><span style="font-size:11.0pt;color:#1F497D;"> &nbsp; </span><span style="font-size:8.0pt;color:#1F497D;">920.437.6400 Ext. 337</span></div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="font-size:8.0pt;color:#1F497D;">Site ID:</span><span style="font-size:11.0pt;color:#1F497D;"> &nbsp;&nbsp; </span><span style="font-size:8.0pt;color:#1F497D;">27450-E905702A-SQL64</span></div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">Wisconsin Converting, Inc.</span></div></div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">&nbsp;</span></div><div><div style="border-top:solid #E1E1E1 1.0pt;padding:3.0pt 0in 0in 0in;"><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><b><span style="font-size:11.0pt;">From:</span></b><span style="font-size:11.0pt;"> <a rel="nofollow" shape="rect" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a> [<a rel="nofollow" shape="rect" target="_blank" href="mailto:vantage@yahoogroups.com">mailto:vantage@yahoogroups.com</a>] <br clear="none"><b>Sent:</b> Tuesday, September 1, 2015 11:55 AM<br clear="none"><b>To:</b> <a rel="nofollow" shape="rect" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a><br clear="none"><b>Subject:</b> RE: [Vantage] Yellow warning message bar</span></div></div></div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal">&nbsp;</div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal">&nbsp; </div><div id="ygrps-yiv-1782512693yiv1488596218ygrp-mlmsg"><div id="ygrps-yiv-1782512693yiv1488596218ygrp-msg"><div id="ygrps-yiv-1782512693yiv1488596218ygrp-text"><div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">What’s causing these global alerts to error out or if we can disable them from showing the yellow bar?</span></div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">&nbsp;</span></div><div><div style="border-top:solid #B5C4DF 1.0pt;padding:3.0pt 0in 0in 0in;"><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><b><span style="font-size:10.0pt;">From:</span></b><span style="font-size:10.0pt;"> <a rel="nofollow" shape="rect" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a> [<a rel="nofollow" shape="rect" target="_blank" href="mailto:vantage@yahoogroups.com">mailto:vantage@yahoogroups.com</a>] <br clear="none"><b>Sent:</b> Tuesday, September 01, 2015 11:54 AM<br clear="none"><b>To:</b> Vantage<br clear="none"><b>Subject:</b> Re: [Vantage] Yellow warning message bar</span></div></div></div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal">&nbsp;</div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal">&nbsp; </div><div id="ygrps-yiv-1782512693yiv1488596218ygrp-mlmsg"><div id="ygrps-yiv-1782512693yiv1488596218ygrp-msg"><div id="ygrps-yiv-1782512693yiv1488596218ygrp-text"><div>Global Alerts are erroring out</div><div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal">On Sep 1, 2015 12:43 PM, &quot;&#39;Chang, Chia&#39; <a rel="nofollow" shape="rect" target="_blank" href="mailto:cchang@...">cchang@...</a> [vantage]&quot; &lt;<a rel="nofollow" shape="rect" target="_blank" href="mailto:vantage@yahoogroups.com">vantage@yahoogroups.com</a>&gt; wrote:</div><div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal" style="background:white;">&nbsp; </div><div><div><div><div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal" style="background:white;"><span style="font-size:11.0pt;color:#1F497D;">We are getting a yellow warning message bar on the bottom left of the main screen.&nbsp; How do we disable these warning message alerts?&nbsp; Currently it is yellow and indicates ‘Ready’.</span></div></div></div></div></div></div></div></div></div></div></div></div></div></div></div></div><div><div class="ygrps-yiv-1782512693yiv1488596218MsoNormal"><span style="color:white;"></span></div></div></div></div></div></div>
</div>
<div class="ygrps-yiv-1782512693yiv1488596218yqt6341568502" id="ygrps-yiv-1782512693yiv1488596218yqt08322"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218 -- #ygrps-yiv-1782512693yiv1488596218ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-mkp #ygrps-yiv-1782512693yiv1488596218hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-mkp #ygrps-yiv-1782512693yiv1488596218ads {
margin-bottom:10px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-mkp .ygrps-yiv-1782512693yiv1488596218ad {
padding:0 0;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-mkp .ygrps-yiv-1782512693yiv1488596218ad p {
margin:0;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-mkp .ygrps-yiv-1782512693yiv1488596218ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-sponsor #ygrps-yiv-1782512693yiv1488596218ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-sponsor #ygrps-yiv-1782512693yiv1488596218ygrp-lc #ygrps-yiv-1782512693yiv1488596218hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-sponsor #ygrps-yiv-1782512693yiv1488596218ygrp-lc .ygrps-yiv-1782512693yiv1488596218ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218activity span {
font-weight:700;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218activity span span {
color:#ff7900;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218activity span .ygrps-yiv-1782512693yiv1488596218underline {
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 .ygrps-yiv-1782512693yiv1488596218attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 .ygrps-yiv-1782512693yiv1488596218attach div a {
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 .ygrps-yiv-1782512693yiv1488596218attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 .ygrps-yiv-1782512693yiv1488596218attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 .ygrps-yiv-1782512693yiv1488596218attach label a {
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 .ygrps-yiv-1782512693yiv1488596218bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 .ygrps-yiv-1782512693yiv1488596218bold a {
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 dd.ygrps-yiv-1782512693yiv1488596218last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 dd.ygrps-yiv-1782512693yiv1488596218last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 dd.ygrps-yiv-1782512693yiv1488596218last p span.ygrps-yiv-1782512693yiv1488596218yshortcuts {
margin-right:0;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 div.ygrps-yiv-1782512693yiv1488596218attach-table div div a {
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 div.ygrps-yiv-1782512693yiv1488596218attach-table {
width:400px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 div.ygrps-yiv-1782512693yiv1488596218file-title a, #ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 div.ygrps-yiv-1782512693yiv1488596218file-title a:active, #ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 div.ygrps-yiv-1782512693yiv1488596218file-title a:hover, #ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 div.ygrps-yiv-1782512693yiv1488596218file-title a:visited {
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 div.ygrps-yiv-1782512693yiv1488596218photo-title a, #ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 div.ygrps-yiv-1782512693yiv1488596218photo-title a:active, #ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 div.ygrps-yiv-1782512693yiv1488596218photo-title a:hover, #ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 div.ygrps-yiv-1782512693yiv1488596218photo-title a:visited {
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 div#ygrps-yiv-1782512693yiv1488596218ygrp-mlmsg #ygrps-yiv-1782512693yiv1488596218ygrp-msg p a span.ygrps-yiv-1782512693yiv1488596218yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 .ygrps-yiv-1782512693yiv1488596218green {
color:#628c2a;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 .ygrps-yiv-1782512693yiv1488596218MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 o {
font-size:0;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218photos div {
float:left;width:72px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218reco-category {
font-size:77%;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218reco-desc {
font-size:77%;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 .ygrps-yiv-1782512693yiv1488596218replbq {
margin:4px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-mlmsg select, #ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 input, #ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-mlmsg pre, #ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 code {
font:115% monospace;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-mlmsg #ygrps-yiv-1782512693yiv1488596218logo {
padding-bottom:10px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-msg p#ygrps-yiv-1782512693yiv1488596218attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-reco #ygrps-yiv-1782512693yiv1488596218reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-sponsor #ygrps-yiv-1782512693yiv1488596218ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-sponsor #ygrps-yiv-1782512693yiv1488596218ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-sponsor #ygrps-yiv-1782512693yiv1488596218ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1782512693 #ygrps-yiv-1782512693yiv1488596218 #ygrps-yiv-1782512693yiv1488596218ygrp-vital ul li:last-child {
border-right:none !important;}
