Zeusqa.sysconfig
Hi, I can see two config files one of which is zeusqa.sysconfig. Being a bit lazy, but does anyone know what is this. I can see some references.
Many thanks
A client config for Zeus QA learning?
Hi, sorry but we don’t have any environments for that locally. Apologies this is the first time we have upgraded to this latest version. Also, we see testfw.sysconfig. But this is not just the in the config folder but also when we launch the client install. we haven’t finished the upgrade fully yet.
Thanks for the prompt reply. We do have a server on our network called zeus but has nothing to do with epicor.
That’s not a standard Epicor config file. Someone may have added it for another application or something. But it’s not an Epicor config file.
That’s a testing file that Epicor uses Internally and sometimes it comes out to play you may ignore it. I’ve seen it a few times.
Odd. It’s never showed up in our installs. Wonder what determines when it shows up.
Hera.
Hera showing up usually makes Zeus disappear.
That, or your config file is turned into an animal to hide it from Hera.
I’ve seen it sneak in on Patches sometimes and or One Off’s.
It’s one that QA (hence the name) uses for testing, and sometimes it gets packaged with the deliverable by accident.
Showed up in our 10.2.500.11 patch client deployment.
