I have seen this problem before, but can not remember the solution. What do
you have the -b setting value up to? Long shot, but did you install all the
service packs for 91d?
Steve
Sent: November 23, 2007 1:44 PM
Subject: RE: RE: RE: [Vantage] [6.1] New Server...Extremely Slow Clients
Raid is 1+0 (I guess that's 10) ...both system volume and vantage
volume...each is a pair of 72GB 15K SAS disks with a standby failover
warm-spare for each volume. The DB is set to start up 4 APWs. Also 4 clients
per server and 15 servers on the mfgsysGroup.
Performance from my PC which gets login screen OK is about the same as from
others once they are logged in. At least no slower than on the old server.
The part that will freak people out on Monday would be the 3-4 minute wait
for a login screen. No amount of informing and begging is going prevent
people from double clicking the Vantage icon again and again....only slowing
it down even more.
-Todd C.
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of vantage
Sent: Friday, November 23, 2007 1:27 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Todd,
What raid is the new server set up as? It should be raid 10. What speed
are the hard drives 15000?.How many apw is the data base set up to use?
Steve
<mailto:todd.anderson%40sbcglobal.net>
sbcglobal.net<mailto:todd.anderson%40sbcglobal.net>]
Sent: November 23, 2007 1:12 PM
.com<mailto:vantage%40yahoogroups.com>
Todd,
Does that fancy new server use TOE? ( TCP/IP Offload engine )
If so, that's probably your issue. MS released some updates that conflict
heavily with TOE logic causing just miserable performance.
I've been dealing with it on newer Dell 2900 servers of late.
Not a Dell problem - it's a TOE chipset issue.
If it does use TOE give me a call - 815-985-8193
Todd Anderson
_____
Behalf Of
Todd Caughey
Sent: Friday, November 23, 2007 11:12 AM
Not yet. Was going to do that later after current problem was resolved. But
will elevate that as a priority. Dual Quad CPUs so has 8 cores so was going
to set -spin to 160,000 but did note in the Progress tuning document that
for systems with low number of users (like our 33) it supposedly does not
matter as much as long as it is fairly large....they suggest 50,000. So I
was going to use that for a start.
But they ar enot clear where this goes. I was assuming adding -spin 50000 to
the .pf file....or is this a setting in PET? Same with the buffers...was
going to set for 2GB max (system has 8GB) but had not flooked yet for where
to make that setting.
Another curiosity....now my PC won't run Vantage at all....Control-Frame
error...meaning I too had references to old server. Cleaned my registry with
no success so will now uninstall Progress Client and re-install. Will be
interseting if I then have slow login screen where as when the old server
was running I had fast connection to the new server.
-Todd C.
Behalf Of Michael Barry
Sent: Friday, November 23, 2007 10:51 AM
Hi Todd,
I'm assuming that your new server is one of the multi-core/multi processor
varieties? If so have you set the DB buffer blocks and spin lock retries
appropriately?
Regards,
Michael
.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups
<mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com>]
On Behalf Of
Todd Caughey
Sent: Friday, November 23, 2007 8:30 AM
Yes, Net Logon service is running. I get same results whether logged in as
the user or logged in as Administrator (which is a domain admin).
-Todd C.
.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ]
On
Behalf Of Jasper Recto
Sent: Friday, November 23, 2007 10:24 AM
To: 'vantage@yahoogroup <mailto:%27vantage%40yahoogroups.com>
s.com<mailto:%27vantage%40yahoogroups.com>
<mailto:%27vantage%40yahoogroups.com> '
Subject: RE: RE: [Vantage] [6.1] New Server...Extremely Slow Clients
Make sure that net logon is running on the clients.
Also, try changing one client to a domain admin to see if it's a security
authentication issue.
Just a thought.
Jasper
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]On
Behalf Of Gary Parfrey
Sent: Friday, November 23, 2007 10:53 AM
Subject: RE: [Vantage] [6.1] New Server...Extremely Slow Clients
Todd
Have you checked the exclusions for the local temp directory
Gary
<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
[mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On
Behalf
Of Todd Caughey
Sent: 23 November 2007 15:19
Subject: [Vantage] [6.1] New Server...Extremely Slow Clients
On the off chance some people have taken refuge from Black Friday
shopping madness or our non-USA freinds are hard at work while most
Americans sleep off Turkey stupor.....
I am switching all my clients over to our new, supposedly blazing fast,
server. But am running into extreme slow logins and some slowness once
Vantage is logged into. Not at all what I was expecting. I have tried
all the usual tricks but nothing has helped. Odd thing is the remaining
Win-98 PCs startup almost instantly and do run very fast. Also my own XP
desktop PC....setup pretty much like everyone else, is really fast
too... as are a couple others. The ones slow to get a login screen (avg.
3-4 minutes) are also the ones that Progress did not uninstall correctly
and I had to remove the PSC and Progress references from the registry.
So far I have done the following, without success...
- Double checked virus scan exclusion of mapped drives
- Disabled virus scanning altogether (temporarily)
- Checked HOSTS/SERVICES files
- Shutdown the old Vantage server
- Unreg the OCXs and ran instOCX
- Unisntalled everything and re-installed
- Disabled Data Execution Prevention (on XP clients)
- Deleted all references to old server from registry
- Changed NIC on client to not autodetect the speed...and bolted in
100Mbps/Full Dup
- Double checked that Windows firewall is disabled (something Win-98 did
not have)
Since it does run very quickly on the server itself I suspect a network
issue but the same network was runing the old server just fine. Which
narrows it down to perhaps a setting on the new server. I am wondering
if there is some "feature" that Win-98 is too old to "take advantage of"
which would explain its relative quickness. In the past most speed
problems I have seen were DNS related. Given the Progress uninstall
problems I am thinking there is some old residue that points to the old
server and this is causing network or DNS confusion for the clients but
I can't figure out where this residue might be.
Any suggestions would be very much welcomed. In the mean time I'm off to
keep uninstalling and re-installing clients.
Todd Caughey
Harvey Vogel Mfg. Co.
Steve
it down even more.
-Todd C.
Behalf Of vantage
Todd,
Steve
Todd,
Todd Anderson
_____
Behalf Of
Todd Caughey
-Todd C.
Hi Todd,
appropriately?
Regards,
Michael
On Behalf Of
Todd Caughey
-Todd C.
On
Just a thought.
Jasper
Todd
Gary
Behalf
Of Todd Caughey
100Mbps/Full Dup
not have)
Todd Caughey
