905.701 - Monitor print speed
Thanks guys. Didn’t realize that the dialog box can take that long. Thought ours was slow, but just timed it and was about 6 seconds.
I haven’t tried your steps 2 and 3 aidacra, so I’ll try those. You said “automating the timing info is definitely possible”. Do you mean that there’s a way to automatically measure the time in steps 1-3? Right now I’m assuming for step 1 I’ll just use a stopwatch, for step 2 I can compare start time in System Monitor to the time the XML was created, step 3 will need stopwatch again.
