BPM "Intellisense" Gone in 10.2.200?
Issue
When using the Custom Code (e.g. using BPM containing the Execute Custom Code), the Autocomplete window no longer appears like it used to up to version 10.1.400.
Error
NA
Resolution
Since ERP 10.1.500 the Autocomplete needs to be activated by typing Ctrl+Space in the Enter Custom Code windows.
Notes
If no suggestion is available when you press CTRL+Space you will see a “No suggestions” message.
The change was introduced in 10.1.600 for performance reason, so as not to slow down when people did not need the Autocomplete.
The CTRL+Space is not documented in 10.1.600 Help Section. That will be remedied in version 10.2.200, under BPM Workflow Designer > Callers > Execute
