BPM Method Directive Incompatible Data Type Error
The Query Designer in a BPM Condition only alows you to choose Column Names. You cant edit and add the cast() part.
I think the following will work
  1. Add a Variable of type DMR Processing Tableset:
  2. Add a Fill table by query widget with:
    The DMRHead subset query being:
    With the columns
    the configured mapping:
    with the expression for PurPoint being:
Now you have a copy DMRHead, where the PurPoint column actually holds the DMRNum, but as a string.
  1. In the condition, make the query:
    (note that UD06.Key1 is linked to DMRHead.PurPoint)
    And don’t forget to add the table criteria for jobNum to UD06
It saves without error, and I believe it should work. But I’m unable to test it.
