In GetLaborDetails you are declaring dt as a new DataTable, not updating dt (which you must have as a class-level member variable, that you are accessing in the button click?).
If you want to update member variable dt instead, the code would look like this:
private void GetLaborDetails(string JN, string PN, string OC)
DynamicQueryAdapter gld = new DynamicQueryAdapter(oTrans);
gld.BOConnect();
QueryExecutionDataSet qeds = gld.GetQueryExecutionParametersByID("ClockOutBarcode");
qeds.ExecutionParameter.Clear();
qeds.ExecutionParameter.AddExecutionParameterRow("JobNum",JN,"nvarchar", false, Guid.NewGuid(),"A");
qeds.ExecutionParameter.AddExecutionParameterRow("PartNum",PN,"nvarchar",false, Guid.NewGuid(),"A");
qeds.ExecutionParameter.AddExecutionParameterRow("OpCode",OC,"nvarchar",false, Guid.NewGuid(),"A");
gld.ExecuteByID("ClockOutBarcode");
dt = gld.QueryResults.Tables["Results"];
You could have GetLaborDetails return the datatable:
private DataTable GetLaborDetails(string JN, string PN, string OC)
gld.BOConnect();
return gld.QueryResults.Tables["Results"];
And use it like this:
private void EndWQtyButton_Click(object sender, System.EventArgs args)
var dt = GetLaborDetails(JobBox.Text,PartNumBox.Text,OpBox.Text);
MessageBox.Show("Test 0 button- JobNum:"+ JobBox.Text+" PartNum: "+PartNumBox.Text+" OpCode: "+ OpBox.Value );
MessageBox.Show(dt.ToString());
