Documenting BAQs
In theory, I have a GitHub repository for exports of all of our customizations. In practice, I’m the only one who knows more about it than “it exists” and I haven’t updated it in ages.
More recently I’ve been documenting everything in a Word document. The BAQ section is 6 pages long—we don’t really have a lot that are shared and I chose to only document shared BAQs unless there was something noteworthy about a non-shared BAQ.
Even have a subsection for the ones I’ve borrowed from helpful EpiUsers :slight_smile:
Dependencies are a problem that version control doesn’t solve. Auditing consumers of BAQ’s is an almighty pain. Will modifying this BAQ break a spreadsheet I didn’t think of? What’s going to break when this API key gets rotated?
There’s an unavoidable make-sure requirement to identify requirements and dependencies in a consistent way. Any time a BAQ consumer is created or modified, that needs to be consistently and verbosely noted at the BAQ.
I don’t really track BAQs individually.
I do use the Comments to add dates/notes about the purpose, quirks, and change history.
Primarily, I track solutions. A solution might consist of:
  • BAQ(s)
  • App studio app
  • App customization
  • Menu entry
    or
  • BAQ(s)
  • Report data definition
  • Report definition
  • Report style(s)
  • Menu entry
    etc.
Solutions are backed up with Solution Workbench and documented in a shared Google Drive doc, with revision history. I’ve thought about Github, but since no one else here would comprehend that, then if I leave they’d have no documentation.
It would be ideal to track all BAQs individually, but the ROI just doesn’t seem to be there.
Solution Tracking is a good idea. I had used the solution workbench when they first released it. I guess it worked alright, it is just slow and clunky.
The one thing to watch out for with Solution Workbench is the dependency problem that John mentioned. If I ALWAYS build a new solution as I need it, then there shouldn’t be a problem. But if I share a Directive or BAQ between multiple solutions, then I may have a previous version in one .CAB file and overwrite a newer version from another .CAB.
IFF, I have a textual way to represent all of my code (directives, layers, customizations, functions, minimal APIs, etc.) then I at least have a shot of finding the BAQ in any customized component with a simple search.
Using an ‘Admin’ user for dashboard/report related BAQs is what we’ve done. That removes them from personal lists so they don’t get forgotten about, accidentally deleted in a ‘rage cleanup’. If a change needs to be done we can just ‘Change Author’ back to ourselves, make the edit, then change author back to admin and it’s back where it needs to be, keeping our personal collection alot cleaner.
Prefixes for multi company is a good idea and is what we’ve done too. I’m not so keen on the numbering but i’m sure there’s value in that depending on your company size.
We used to have a series of solutions which were stored in order of dependency, which worked ok. Not perfect, but ok.
Not being able to easily see inside solutions for their content, and even worse when they were installed, the only simple way to see that they were installed was to go and try and delete them… Less than ideal. I have not looked recently if that has changed.
Fair warning, I don’t have a professional bone in my body. :upside_down_face:
I have authored about 520 BAQs in the past ~3 years. A handful of them are useful. All created in 10.2.400, so none of them have comments. Aside from sticking to naming conventions, I created a dashboard to search them by different criteria.
There are several prefixes I use to determine if the BAQ is for production, for reference, a simple data request, or is a template for complex and reusable structures.
And lastly, I always include the Report ID and SSRS file location in the footer of every report so I can track things down later on.
I like this idea! I don’t have a dedicated admin account, just a me and one other person that are Security Managers. Do you have an account named something like “admin” with security manager permissions? This seems like it should be the proper way to do BAQs you need for daily company work. IDK why we haven’t done that yet. :thinking:
Some DevOps teams (no Epicor users that I’m aware of) have deployment accounts. Nobody but that one deployment account can push to production. The deployment system keeps track of the changes. It’s a nice model for those with SOX requirements.
Seems to fit well with POLP.
Yes. we have a UserID ‘Admin’, security manager permissions, etc. I’m not sure the user would even need much permissions as it’s just a holding ground for BAQ’s, it’s not like that user is ever logged into to create a BAQ’s or dashboards etc, we just take control of the BAQ when we need to update, and change it back when we’re done.
I am using an external project management software for all documentation, requirements, attachments and so on (Atlassian Jira). The BAQ ID is exactly the Jira ID so I know where to go for all the related documentation. Of course instead of Jira ID you can use the ID from your internal support ticketing system and of course, use also the comments Tab in the BAQ. This way when it needs updates I can get back to the original request and see what was requested 2 years ago.
I have been using Smartsheet to track requests and note BAQs and others
It allows attachments so I will export BAQs
I have created a BAQ on the query table. One field holds the logic so you can search for a query that is using a particular table or function
This BAQ was updated on the latest version 2024.2.12
XS_BoB.baq (13.0 KB)
Don’t forget you can do some BPMs to track who executes each BAQ and when (to a UD table). I use this to determine unused BAQs which I then export and remove from the system.
Combined with naming conventions we can keep our list cleaned up.
We’re about to move to 2024.2 and I plan on using the comment field.
Doug,
Would you be able to share details on that BPM? It seems like a fantastic way to see who’s using what. We’re in the middle of our migration to Kinetic (from the Classic UI), and managers often ask ‘Who’s running this dashboard’ when I show them the activity log. Thanks!
It’s a preprocessor method directive on the Ice.BO.DynamicQuery Execute method:
The first BO Method above are getting a new record from the UD table (in my case UD20). The last BO Method is the update.
This is my code block:
var row = dsUD20.UD20.First();
row.Company = callContextClient.CurrentCompany;
row.Key1 = queryDS.DynamicQuery.First().QueryID;
row.Key2 = DateTime.Today.ToString("yyyy-MM-dd");
row.Key3 = DateTime.Now.ToString("HH:mm:ss");
row.Key4 = callContextClient.CurrentUserId;
row.Key5 = Guid.NewGuid().ToString();
row.CheckBox01 = queryDS.DynamicQuery.First().SystemFlag;
row.ShortChar01 = "Execute";
row.ShortChar02 = DateTime.Now.ToString("yyyy-MM-dd HH:mm:ss.fffffff");
if (callContextClient.AssemblyName == null)
  row.Character01 = "BAQDesigner";
else if (callContextClient.AssemblyName == string.Empty)
  row.Character01 = "REST";
else
  row.Character01 = callContextClient.AssemblyName;
row.RowMod = "A";
You can change anything you want…
I have one for ExecuteByID as well. It’s in a strange place and I have to go back through my notes. It’s the same setup except you change these lines from:
to
row.CheckBox01 = Db.QueryHdr.Where(q=>q.QueryID==queryID).Select(q=>(bool?)q.SystemFlag).FirstOrDefault() ?? true
row.ShortChar01 = "ExecuteByID";
True. For folks who still don’t want github.com there’s Azure Dev Ops (unlimited repos, 5-users free) https://dev.azure.com/
it is possible to create your own remote repos
with git installed locally, you just
cd mydir
git init
now you can simply open the directory and see, commit, diffs in any software with git integration such as VSCode
I completely scanned right past this before. BTDT! There’s just this one clunky step that git hub/lab/whatever do that you don’t see. As seldom-used git incantations go, this one’s not bad.
Say you wanted to make a remote “development” repo:
  • Starting with a working repo lets you ignore some potential arcanity. If you already have something, great. If not, say git init wherever you’ll be doing your work.
  • Go to where you want your “development” repo and say git init --bare. A repo that can be added as remote having to be a bare repo is the clunky part. It’s the part github does that you don’t see.
  • Hoof it back to your working repo. Say git remote add origin <development repo path>. Just like adding a remote relationship to a github repo.
  • You can optionally put a little bow on top with git remote rename origin development so it has an intuitive name, especially if you have more than one remote.
  • You’re good to go. Add / commit / push / fetch / pull / etc work like they would if the remote path was a url.
Convincing everyone to never work directly in the development repo is the actually hardest part. Doing all the things that git hub/lab/whatever handhold can be frustrating sometimes, but editors offer lots of handholding these days. Lots of self hosted helper solutions are out there too. If storing work on resources you don’t fully control isn’t viable, this is the way.
Heres a little gitinit.cmd script I run on any parent dir like:
C:\SomeDir > gitinit ChildDir
to:
  • initialize git on sub dir
  • add readme and .gitignore
  • create github repo
  • commit local repo
  • add remote (github)
  • push to remote (github)
after that I use VSCode UX to diff, commit, and sync
@echo off
for /f "delims== tokens=1,2" %%G in (token.secret) do set %%G=%%H
cd %1
git init
echo "README" > README.md
(echo /bin && echo /obj && echo *.log && echo *.dacpac && echo *.bacpac && echo !/refs/*.dacpac) > .gitignore
git add .
echo "Authorization: token %Token%"
curl -X POST -i -H "Authorization: token %Token%" https://api.github.com/user/repos -d "{\"name\": \"%1\"}"
git commit -m "first commit"
git remote add origin https://github.com/%User%/%1.git
git branch -M main
git push -u origin main
cd ..
git submodule add https://github.com/%User%/%1.git
PS - I think git remote add uses github auth in VSCode since I’m typically running this in VSCode Console(?)
