I just did that with a bat script and it worked fine. Going to try to run the bat script on startup via GPO. Thanks for your help so far
Just a heads up, it is a very very bad idea to store files on azure file share. Epicor can choose to cleanup this at anytime without warning if it is using too much disk space (or any reason really) and you will lose everything.
I have always treated the azure file share like volatile storage, the primary purpose and usage has always been processing bartender files. Not intended to be used as a file server
That is my understanding too. Azure file share is provided for the sole purpose of the bartender integration. If you need file storage they sell ECM cloud.
Or SharePoint Online, DropBox, and maybe one other. ![]()
Google drive. And none of them require edge agent. As the result they won’t open an attachment in separate view program either.
