I would think that when the user selects another PO, you could verify under epiViewNotification in Initialize, if your currentrow has changed…? I use this method under Order entry. I have a global variable having the current OrderNum. and under Initialize, I compare that value with the currentrow ordernum…if different i access my code…
maybe that could work for your issue?
Pierre
