Rick,
Glad i could help out a little. I am going to copy paste the long winded solutions sheet Epicor Support sent me in hopes that in can help you and your client. i am currently trying to update all of our resources but one other little fix that made a difference was we did not have a calendar setup in the site maintenance menu (this is also on the list). Its almost like a backup calendar so if the scheduler comes across a resource with no calendar, it will default to the site maint. calendar instead of having nothing at all. i changed that and removed double resources on a job and i was able to schedule without a problem. Anyway here is the VERY long list from Epicor. Hope it helps…
MRP/Scheduling process is hanging – looping why? May also be running at a very slow speed, takes a long time to complete, the MRP log files may appear to have a lot of idle time in them where it appears no data is being processed; entries may say Waiting For Next Part, Waiting for Next job. Possibly in Job Entry manually scheduling a job may also hang or be looping.
RESOLUTION
There are several reasons why when running Global Scheduling/MRP the system hangs loops. And in most cases it is due to a file which is growing out of control and the only way to stop it is to stop and restart the apps servers. Below is a list of things to look for when trying to determine what is causing this. And in all below examples this will happen when users are also finitely scheduling.
Operations have both the same Resource Group
– Resource list relationship in Job Entry when viewing Job Entry and for a selected operation look at the Job details tab > Operations tab > Scheduling Resources tab > Detail tab.
If the Resource here is from within the same Resource Group, this can definitely cause MRP/Global Scheduling to hang. When reviewing the scheduling logs you need to determine where it starts looping or you might see that it is finding Conflict with another job and the logs show the same job number repeated over and over.
If the Conflict is another job, you need to bring that job up in job entry and the logs will tell you what assembly sequence/operation to look at. If you determine that it is because of the resource group/resource then the user needs to determine which one to schedule to and remove the other one from this job operation and reschedule the job. If it is determined that their Methods are setup in the same fashion, as viewed in Method Tracker / Engineering Workbench they will need to fix those as well, per the Engineering Workbench and/or Operation maintenance under Job Mgt > Setup > Operation. A Resource Group and one of its own Resources cannot be here as Scheduling Requirements although the software allows you to add them as such and save. -
Calendar ID has a spaceWhen reviewing the scheduling logs when you determine where the scheduler starts looping you then need to go to job entry for that job and look at that assembly/operation sequence and then go to the resource group and view the calendar. If it is determined that the calendar has a space in front of the ID will need to request a fix program to eliminate the space.
Operation has long estimated production hrs. example 100 +When reviewing the scheduling logs when you determine where the scheduler starts looping you then need to go to job entry for that job and look at that assembly/operation to look at the total Productions Hours. If these hours are over 100 the user needs to determine if this is a legitimate standard or not and if not change it so these hours are less than 100 and reschedule the job.
Establish a finite horizon (When using finite scheduling)If it is determined that the customer has demand which goes out further than 1 year and they have no Finite Horizon set up on their resource groups/resources they might want to consider establishing one. They also might want to refer to the scheduling technical reference guide if they have questions as to how this will effect scheduling.
Check Resource Groups/Resources and ensure the number of Resources in the tree view on the left match the number showing on the resource group form Detail tab under the Scheduling section on the right, field titled Number of Resources.If it is determined that this is the issue to fix it all that needs to be done is go to the resource tab and move one resource out and move it back in and now see if the view and form will be in synch. This can be verified by reviewing the tree view again and comparing it to number of resources on the resource group form.
But the user will need to run Calculate Scheduling Order and Global Scheduling to fix all current jobs in the system so they are scheduled appropriately.
(this may be related to Change Request Page 38416mps-8772esc and SCR 81671) -
Production Calendars which have a gap in them (they run 8 hour shifts but have 4 consecutive hours checked followed by a gap of one or more hours not checked then the remaining 4 consecutive hours are checked.) Most users might set up calendars with a gap for lunch but this is not the place to identify it, that is in employee set up or Shift maintenance itself.This causes looping because the scheduler is looking for a consistent run of time and is not able to make the jump over the gap. This unchecked box must be checked. Also, do not forget to go into Resource Group maintenance and look under the Calendar Exceptions tab for the group itself to see if this gap problem exists on any certain days. Also look in the Resources tab > Calendar for similar exceptions that may have been established for a specific resource.
See the Word do attachment to this page = 13766mps-6-screenpics.docx for more information and details on this topic. -
Company Maintenance /Company Configuration and Plant Maintenance / Site Maintenance screens all have Production Calendar fields that must be populated. Make sure these fields are populated with valid working calendars from Production Calendar Maintenance.
Similar screen referred to above in Job Entry per step 1, Job details tab > Operations tab > Scheduling Resources tab > Detail tab. Middle section with the fields for Capability / Resource Group / Resource, only one of these fields should be populated. If more than one of these are populated for a Scheduling Resource below an op, this can cause any scheduling function to hang, Job Entry – MRP – Global functions. Make sure only one of these fields is populated, here and in the Method Tracker–Engineering Workbench where Get Details is done from. Do Actions > Job Details > Operations > Add Scheduling Resource to add another Resource Scheduling item here with only one of these fields populated. See the Word doc attachment to this page = 13766mps-7-screenpics.docx for more information and details on this topic.
In the Resource Group Detail screen, do not check the Use Calendar for Move Time and Use Calendar for Queue Time fields unless the related fields for Queue Hours and Move Hours are set to greater than 0.00. If the hours fields are left at zero and one or both of these boxes is checked, MRP – Scheduling may hang, lock, not complete or not run correct. See Word doc attachment to this Page = 13766mps-8-screenpics.docx for this screen.
In Resource Group entry, on the main Detail tab in the lower right uncheck the Use Calendar for Move Time and Use Calenar for Queue Time boxes if the Move and Queue Hours fields are left at 0.00 above and also in the Resources tab. When these fields are left at zero, these boxes should not be checked.
Resource Group Detail screens and Resource Detail screens, make sure the calendar fields are populated with valid calendars. If these fields are blank here, then the software looks for default calendars in the Company maintenance and Plant maintenance screens and their Calendar fields,so make sure these fields are also populated with valid calendars.
If the AMM module, Advanced Material Management, is installed, then go to Resource Group entry, for each group in the Detail screen the Location box must be checked and the Input and Output Warehouse and Bin fields must be populated. Same for each resource in the Resources tab > Detail tab. See the Word doc attachment to this Page = 13766mps-10-screenpics.docx.
Database Appserver log, see Page 7469mps for more details, located in the
\epicor\epicor905\server\logs directory, look for the databaseID.server.log file. Look for entries recorded during the time that MRP is running and more towards the time that it appears to stop and hang – lock that indicate it is conflicting with another function or process on the server. Recorded lines here may directly Conflict, Conflicts, Conflicting.
Or these lines may say something about a BPM created under System Management > Business Process Management. Turn off these BPMs or possibly all BPMs prior to running MRP to avoid lockups. -
Database Replication running at the same time as MRP can also cause it to hang – lock, again turn this off before MRP is run. Replication is a process where data in the current database is copied to a different database. A recorded line in the appserver log may look like this while it is running:
– (Procedure: ‘replicate Bpm/DataTrigger.p’ Line:-1) -
Run the 5100 database conversion to help possible low level code problems for parts that may be a bit out of synch or corrupted. (Version 10.0+, it’s now the 1040, see Page 164542esc below for instructions) Located of the server in the Database Admin Tools > click open the Conversion Programs button. This will resynch these codes for parts that may be corrupt and out of synch. See general info Page 3588mps for more information about these codes. Stored in the Part table, LowLevelCode field, inital value is 0. Short definitiion, it represents the lowest level indentation a part is used in parent Revision – BOM structures.
Do a BAQ–Export on the part table and include this LowLevelCode field. If any value looks incorrect, in the 100’s, 1,000’s, then this 5100 conversion will definitely have to be run to try and correct these values to their correct amount.
An early clue here may be when MRP runs and its log file says Building PartList Level over and over followed by numbers. These numbers represent the Low Level Code – BOM level indentation it is currently processing; if numbers here look abnormally high and unrealistic, it could indicate Lowlevelcode problems that need to be fixed and corrected by this 5100 conversion. A manual fix program may also be required from support that has to be installed and run if the 5100 conversion does not fix the problem low level codes -
The Revision / BOM for a parent part calls itself out as a material or subassembly of itself. This may also cause its Low Level Code field to be inflated far above its normal amount. When looking a parent revision either in the Engineering Workbench or Method Tracker, look thru its Material list. If this same parent part is also a part number in a Material sequence Detail screen, delete this sequence or change the part ID itself.
If there are subassemblies, this parent also cannot be the part ID in any Subassembly Detail screen nor can it be the part in any material sequence below any subassembly.
In the Engineering Workbench, when you try to add the parent below itself in either of the above scenarios you will be stopped by the message " Circular Reference " either when trying to save the material or when Approving the Revision and attempting the Check In back to Part entry. So if the above problem exists, the data must have been imported into the database from outside sources and not created manually in the Engineering Workbench.
A clue that the above problem exists and is causing MRP problems is to input a log file on the Process MRP screen, then look at the related MRP basic log file that is created while MRP runs. Shortly after it starts running it will go into a section where every entry is titled Building PartList Level: xx where the xx represents the Low Level Code assigned to a part that is processed. Usually this will be anywhere from 0 up to 5 or 10, maybe 20 or higher, dependent on the lowest subassembly level that a part is used at.
If this number starts becoming inflated and is abnormally high for all these Building Partlist entries, such as in the hundreds, thousands, this indicates that MRP has encountered a part or some parts with the above Circular problem and is now hung up and looping on them.
RESOLUTION:
Do an export from the Part table selecting just a few fields such as PartNum, PartDescription, LowLevelCode. Find the parent parts that have an inflated, abnormal code. Then go to Part entry and checkout their revision to the Engineering Workbench and correct the above problem with the material sequence or subassembly sequence of the same part ID. Followup by running the 5100 database conversion per above step 10 to properly synch up these codes that may also be out of sync at this point.
If for some reason the above Circular problem does not exist but inflated Low Level Codes still exist causing the looping/hanging problem, then the fix program from change request Page 37099mps may need to be sent out to fix the problem codes. And if this fix does not work, then a copy of the database will need to submitted to Epicor support and programming for further review.
Part table > LowLevelCode field definition. (from the Data Dictionary in System Management)
Internally assigned integer which indicates the deepest level of assembly indention that this part is used at. This is used by the Cost Rollup routines to control the order in which parts get costed. Part at the bottom (highest levelcode) Product structure are calculated first and continues up the chain, with the final assembly parts being processed last. This insures that when retrieving the cost of an assemblies components the components will already have had their cost rolled up.
If there are multiple scheduling resources in a Job Operation, as viewed in Job Entry in the Job Details tab > Operations tab > Scheduling Resources tab > List tab, the related Production Calendars for these Resources / Resource Groups must have some checked availability hours that overlap. If not, this will cause the Scheduling engine program to hang.
Example, say you have resrc1 and resrc2 listed here in this List tab that need to be scheduled for the operation. Go to Resource Group entry and find their applicable calendars. Then go to Production Calendar maintenance, select these calendars to see what hours are checked.
If one calendar only has hours 1 thru 8 checked while the other calendar only has hours 10 thru 18 checked, the Scheduling program sees this and will lock up and hang because it needs to schedule these resources at the same time, concurrently. It cannot schedule one resource for hours 1 thru 8, Midnight to 8am while it also tries to schedule the other resource at the same time for hours 10 thru 18, 10am to 6pm.
At least one or more hours would have to overlap here and a change needs to be made. Perhaps the hours 1 thru 8 need to be changed to 4 thru 12 so there is some overlap with hours 1o thru 12.
If all appears to check out OK here in the Production Calendar screens, then go back to Resource Group entry and look at the related groups and resources. Perhaps changes have been made to the default available checked hours in the either the Calendar Exceptions tab or in the Resources > tab > Calendars tab. -
Run the 6430 database conversion, Recalculate Part Onhand/Allocation summaries. It may help resynch underlying tables and fields for part data that is out of synch and corrupt. Problems with part data could eventually lead to MRP and Job Scheduling problems.
Also run the 6920 conversion; Delete PartDtl with Invalid Job References. This should delete bad records in the PartDtl table from older jobs that should no longer be processed as part of the current MRP runs. This conversion may not be available in version 8.0x. The PartDtl table holds current Demand and Supply records to be processed by MRP. An export-query-BAQ should also be done from this table to view these possible bad records.
In all above scenarios, to properly troubleshoot the issue we would need Appserver logs and MRP/Scheduling logs to assist further.
Add the companies to the Task Agent user IDs.
Page 16452esc Version 10.xxx Database conversions
PROBLEM DESCRIPTION:
Users need to run a database conversion support suggested to resolve an issue.
Where are these database conversion located in Epicor ERP? 10 10.0 10.0.700
VERSION: 10.0+
PROBLEM RESOLUTION:
- From the main menu go to System Management> Upgrade/Mass Regeneration> Conversion Workbench
- In the left side tree view select User Run Conversion
- Search for the conversion you need to run on the right and double click on it in the ID or Description column.
- This opens a new popup box titled Data Conversion Maintenance.
- From the Actions dropdown menu select ‘Submit’ to apply and run the conversion
- This Popup box has a section at the bottom titled Run Log, it will have data about the process being run.
- Check back in the list of conversions, for the one running now, the ProgStatus column will be Started at the start and change to Complete when it is done.
- Close the Popup box when the conversion is complete.
- Exit this screen or double click open a different conversion to run if needed.
