Frideas 9/13/2024
Understood Tim however the final three URLs aren’t linking correctly. FYI
Plus, +1 to Brandon’s suggestion to make them consistent.
Interesting – do you know if they staged the pack with phantom packs in it before ship confirming?
Ability to mark Operation as Inactive
https://epicor.ideas.aha.io/ideas/KIN-I-3884
Inactive Flag for product group
https://epicor.ideas.aha.io/ideas/KNTC-I-2015
Allow Reason Codes to be marked “Inactive”
https://epicor.ideas.aha.io/ideas/ERP-I-1469
Ability to Deactivate Warehouses
Yes, you create the pack, mark pack closed, then phantom pack it. I don’t remember if staging was before phantom or not.
Tim as a framework and the way the Epicor is written this isn’t as big as it sounds at least in my head.
Add I flag [inactive] to all primary tables
Update the Standard Methods GetRows, GetList etc to filter out any result where inactive=true
and then go from there that would solve 99.99997% of the cases and then the other stuff could be slowly implemented
Heck GetRows and GetList for all BO’s is nothing more than a Stored Proc in the back end so the fix should be pretty seamless
Yes there is nuance and more complicated stuff that later can be layered on but KISS will get us most of the way there.
And if someone doesn’t like it, then just don’t check the box :man_shrugging:
Controlled Release for the Epicor Cloud Management Portal (ECMP - hooray another acronym) will start as soon as we have paperwork finalized - hopefully next week.
Initial Portal Actions will be against Pilot / Additional and provide standard admin functions.
Dare I ask what is E12…?
See
OK… so you take it as the “UXP” version and not the ERP version?
But the 5.0 seems to line up with the ICE version that does change with ERP versions…
Point being, it sounds like an architecture change, is what has me curious.
Either did @mbayley’s idea of changing the yellow-ish icon for complete for jobs but apparently it is. :man_shrugging: Glad to see this is still gauging interest though so hopefully it’ll happen someday.
How do we sign up?
Isn’t using “ZZZ” as the prefix to the description a good solution.
It’s been working as designed for the last 15 years!
You’re not wrong.
