Get details - subassembly structure not maintained?
I believe you’re experiencing the same issue as we did within the Quote\Mfg Details. The link below shows the discussion but basically Epicor advised us ‘that this is an intended behavior and it is working as designed. The functionality has been changed under Problem- PRB0100488, on Version 10.1.400’ when a part is marked as a Phantom BOM.
