Just want to add a bit to the delegates, as I’ve played with them a LOT.
If you need to loop through a List<T> (or other types) and perform an Action on each, there’s a shorter syntax you can use. Example:
var NumberList = new List<int> { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 };
var EvenNumsOnly = new List<int>();
Action<int> AddEvenNums = i =>
if ( i % 2 == 0 )
EvenNumsOnly.Add( i );
NumberList.ForEach( AddEvenNums );
Another fun thing if you have a simple Func<T> or Action<T>, you can keep them in-line. From the example above, my delegate could be:
Action<int> AddEvenNums = i => if ( i % 2 == 0 ) EvenNumsOnly.Add(i);
or for a Func<T>:
// These two delegates do the same thing:
Func<string,string> ValidateString1 = input =>
if ( string.IsNullOrEmpty(input) )
return "Invalid Input";
return "Input is Valid";
Func<string,string> ValidateString2 = input => string.IsNullOrEmpty(input)? "Invalid Input": "Input is Valid";
