jbooker
(Josh Booker)
6
Here’s an md doc generated from events.json schema using json-schema-for-humans. Not bad for a first pass.
events.md
snip:
5.1. The Events Items Schema
Title: The Events Items Schema
| Type |
object |
| Required |
No |
| Additional properties |
Not allowed |
| Property |
Pattern |
Type |
Deprecated |
Definition |
Title/Description |
| + id |
No |
string |
No |
The Id Schema |
| - description |
No |
string |
No |
The Description Schema |
| - trigger |
No |
Combination |
No |
The Trigger Schema |
| + actions |
No |
array |
No |
5.1.1. Property id
Title: The Id Schema
5.1.2. Property description
Title: The Description Schema
5.1.3. Property trigger
Title: The Trigger Schema
| Type |
combining |
| Required |
No |
Not allowed |
| Property |
Pattern |
Type |
Deprecated |
Definition |
Title/Description |
| + type |
No |
enum (of string) |
No |
The type Schema |
| - target |
No |
string |
No |
The target Schema |
| + hook |
No |
enum (of string) |
No |
The hook Schema |
| - columns |
No |
array of string |
No |
The columns Schema |
5.1.3.1. Property item 0
| Type |
object |
| Required |
No |
Any type allowed |
5.1.3.1.1. If (type = “DataView”)
| Type |
object |
| Required |
No |
Any type allowed |
5.1.3.1.1.1. The following properties are required
5.1.3.2. Property item 1
| Type |
object |
| Required |
No |
Any type allowed |
5.1.3.2.1. If (type = “EpBinding”)
| Type |
object |
| Required |
No |
Any type allowed |
5.1.3.2.1.1. The following properties are required
5.1.3.3. Property type
Title: The type Schema
| Type |
enum (of string) |
| Required |
Yes |
Must be one of:
- “Control”
- “Window”
- “EpBinding”
- “DataView”
- “DataTable”
- “Grid”
- “Page”
- “Tree”
- “Event”
5.1.3.4. Property target
Title: The target Schema
5.1.3.5. Property hook
Title: The hook Schema
| Type |
enum (of string) |
| Required |
Yes |
Must be one of:
- “onClick”
- “onLoad”
- “columnChanging”
- “columnChanged”
- “rowChanged”
- “rowChanging”
- “viewChanged”
- “viewChanging”
- “onEpPanelCardCollapsed”
- “onEpPanelCardExpanded”
- “onSearch”
- “epOnClickAdd”
- “onDataDropDownClick”
- “onInit”
- “onBlur”
- “onClosing”
- “onClosed”
- “onTreeNodeExpand”
- “onTreeNodeSelectionChange”
- “onTreeDropItem”
- “onTreeDragEnter”
- “onTreeBeforeExpandAll”
- “onBroadcastData”
- “onItemClick”
- “onLinkClick”
- “before”
- “after”
5.1.3.6. Property columns
Title: The columns Schema
| Type |
array of string |
| Required |
No |
Array restrictions |
| Min items |
N/A |
| Max items |
N/A |
| Items unicity |
False |
| Additional items |
False |
| Tuple validation |
See below |
5.1.3.6.1. The Columns Items Schema
Title: The Columns Items Schema
5.1.4. Property actions
| Min items |
N/A |
| Max items |
N/A |
| Items unicity |
False |
| Additional items |
False |
| Tuple validation |
See below |
5.1.4.1. The action Schema
Title: The action Schema
| Type |
combining |
| Required |
No |
Not allowed |
| Defined in |
#/definitions/eventAction |
| Property |
Pattern |
Type |
Deprecated |
Definition |
Title/Description |
| + type |
No |
enum (of string) |
No |
The type Schema |
| - param |
No |
object or array of object |
No |
The Param Schema |
| - value |
No |
string, boolean, number or null |
No |
The Value Schema |
| - option |
No |
object |
No |
The Option Schema |
| - epBinding |
No |
string |
No |
The EpBinding Schema |
| - dataview |
No |
string |
No |
The Dataview Schema |
| - dataTable |
No |
string |
No |
The Datatable Schema |
| - onSuccess |
No |
array |
No |
In #/definitions/successResult |
The actionResult Schema |
| - onError |
No |
array |
No |
In #/definitions/errorResult |
| - onEmpty |
No |
array |
No |
In #/definitions/emptyResult |
| - condition |
No |
string |
No |
The Condition Schema |
| - variable |
No |
string |
No |
The variable Schema |
| - onOk |
No |
array |
No |
In #/definitions/okResult |
| - onCancel |
No |
array |
No |
In #/definitions/cancelResult |
| - onYes |
No |
array |
No |
In #/definitions/yesResult |
| - onNo |
No |
array |
No |
In #/definitions/noResult |
| - onRetry |
No |
array |
No |
In #/definitions/retryResult |
| - onNone |
No |
array |
No |
In #/definitions/noneResult |
| - onAbort |
No |
array |
No |
In #/definitions/abortResult |
| - onIgnore |
No |
array |
No |
In #/definitions/ignoreResult |
| - expression |
No |
string |
No |
The Expression Schema |
