Multi Resource Scheduling Board Material Grid
I think the best way would be to add a new grid on the screen, to display what you need and keeping the Material Constraints grid as-is.
With Kinetic, you could do roughly the following:
  • Create a BAQ that returns the job materials and all the info you need, for every open job. Something like that
  • Create a new layer on the menu
  • In the application Map, edit the “Job Details” panel
  • At the bottom, insert a new panel card grid
  • Configure the provider model of the panel card grid to call your BAQ
  • Add a where clause in the Baq Option of the provider model, like this
Here’s the result
Edit : hidding stuff and clarifications
