I have experienced exactly this situation myself: right now I have seven confirmed cases where the PkgControlItem.ItemQuantity doesn’t match the PartBin.OnhandQty for the same PCID. I was able to track down why it’s happening, though it’s likely something different in your case.
We have customized the Process by ID screen with a dropdown for PackageControlIDCode. When the user selects from the dropdown, it auto-generates one new PCID and puts the PCID number in the “To PCID” field. The problem was when people were issuing material to a job. In the Base implementation of Process by ID, the “To PCID” field is grayed out when issuing to a job. However, our users were sometimes making a selection from the dropdown, which was re-activating the “To PCID” field. They would get an error, but the damage was already done at that point: the two quantities were now out of sync.
I found the root cause by examining the transactions related to one of the corrupted PCIDs in Part Transaction History Tracker, noticing a transaction issuing the mismatched quantity to a job, and reproducing the situation in our test environment.
We have fixed the Process by ID customization so it will no longer re-activate the grayed out field, which should stop the bleeding, and now I just have the seven items to clean up.
Good luck with figuring out your problem!
