On Thu, Dec 19, 2013 at 12:40 PM, Len Hartka <len.hartka@...> wrote:
Â<div> <p>
Good Day Scott:
Â
           By “full cycle count with no movement†do you mean that you count all the parts in one day ( or a few days)?
           If yes, then there is no real difference.
           Cycle counting comes about when you have a lot of part#’s to count – I have 35,000 in stock at any time.
           Since counting them all in one day ( a P.I.) is a MASSIVE and costly job, you go to cycle counting in order to do some each day.
           Also, very importantly, you classify parts as ABC ( DEF?) based on usage-and-cost. You only count the cheap parts once a year or maybe once every few years. This saves a lot of money. You can do the cycle counts during slow days as a farther way to reduce cost.
           Also, you count the A parts 3-4 times a year since these are the parts that must have a correct balance.
           Final important idea is “What will the Auditors accept†– cycle counts have to be very well documented to make them happy; although, if you do it in one day, they would not care.
Â
           Of course there are also many considerations specific to your company. Are you counting diamonds or coal, do your parts get stolen, how good is your paperwork, do parts go bad, are you Santa Clause so you have a big ‘seasonal†problem.
Â
        Merry Christmas,
          Â
        Len
Â
Leonard C. Hartka
66 Loveton Circle, Sparks, MD, 21152
Work: 410-329-3560 ext 120
FAX: -329-3564
Work Cell: 443-255-7192
Personal Cell: 410-292-8744
Â
Â
Â
Â
Â
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Scotty K.
Sent: Thursday, December 19, 2013 12:41 PM
Subject: Re: [Vantage] Re:Physical InventoryÂ
Â
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.Maybe you guys can help me understand... Why do you need to perform a "Physical Inventory" in Epicor?
As it relates to Epicor, isn't a physical inventory the same as a full cycle count with no movement?
Â
Scott
Â
On Thu, Dec 19, 2013 at 10:52 AM, Len Hartka <len.hartka@...> wrote:
Â
Good Day Jacqueline:
Â
           I do not think E9 can do that.
           You could just do a BAQ using PartQty file ( which list qty in each bin):
                                   Sort by bin#
                                   Paste in to Excel
                                   Print out (have page numbers to be sure you get them all back)
                                   Counters mark up the print out.
                       Need to decide who and how to get the correction, since counters will count 487 and E9 = 349 correction =??? Plus or minus?)
                                   Keypunch adjustments into E9. ( or keypunch into Excell – calculate correction – SORT by Part# ( so Bin moves will be together) -  keypunch correction into E9)
           Create a INV2014 reason code to use for easy reporting on total change.
           Watch out for Date-entered vs Date-transaction—count on 12/31/13, punch on 1/2/14 - affects G\L balances. That is, back-date the entry to 12/31.
          Â
Â
        Len
Â
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jacqueline Restivo
Sent: Thursday, December 19, 2013 11:25 AM
Â
Hi Jordan Thanks for the details of doing a physical inventory.Â
Doing the steps you posted 0 out the existing inventory.We do NOT want to 0 out the inventory, only adjust inventory we have.Â
Is this possible with Physical or only in cycle counting?
thanks
Â
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Thursday, December 19, 2013 10:34 AM
Subject: RE: [Vantage] Re:Physical InventoryÂ
Â
Performing a full physical inventory allows you to adjust the quantities when you enter the tags(Papers with the item counts on them after counting how much in stock.) If you would like I wrote up a procedure for performing full physical inventory. It was done for 9.05.700b, not sure how different that is from 606a.
Jordan
[Bully Dog Logo]<http://www.bullydog.com>
Jordan Klassen | Information Technology
TEL: 940-783-9914 ext: 1828
Confidentiality Notice: The information contained in this electronic message is privileged and confidential information intended only for the use of the individual entity or entities named as recipient or recipients. If the reader is not the intended recipient, you are hereby notified that any dissemination, distribution or copy of this communication is strictly prohibited. If you have received this communication in error, please notify the sender immediately by electronic mail and permanently delete this message from your computer system. Thank you.
Sent: Thursday, December 19, 2013 7:47 AM
Subject: [Vantage] Re:Physical Inventory
Hi All,
Epicor 905.606A
We're planning a physical inventory at the end of the year. We don't want to 0 out our existing inventory, just adjust what's in the system now. Is there a way a physical can be done this way? We haven't had much luck in the past when we 0 it out.thanks in advance
jacqueline
Happy Holidays to you
[Non-text portions of this message have been removed]Â
Â
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.</div> <div style="color:rgb(255,255,255);min-height:0px;"></div>
Sent: Thursday, December 19, 2013 2:10 PM
Good Day Scott:By “full cycle count with no movement†do you mean that you count all the parts in one day ( or a few days)?If yes, then there is no real difference.Cycle counting comes about when you have a lot of part#’s to count – I have 35,000 in stock at any time.Since counting them all in one day ( a P.I.) is a MASSIVE and costly job, you go to cycle counting in order to do some each day.Also, very importantly, you classify parts as ABC ( DEF?) based on usage-and-cost. You only count the cheap parts once a year or maybe once every few years. This saves a lot of money. You can do the cycle counts during slow days as a farther way to reduce cost.Also, you count the A parts 3-4 times a year since these are the parts that must have a correct balance.Final important idea is “What will the Auditors accept†– cycle counts have to be very well documented to make them happy; although, if you do it in one day, they would not care.Of course there are also many considerations specific to your company. Are you counting diamonds or coal, do your parts get stolen, how good is your paperwork, do parts go bad, are you Santa Clause so you have a big ‘seasonal†problem.Merry Christmas,&n bsp; LenLeonard C. Hartka66 Loveton Circle, Sparks, MD, 21152Work: 410-329-3560 ext 120FAX: -329-3564Work Cell: 443-255-7192Personal Cell: 410-292-8744From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Scotty K.
Subject: Re: [Vantage] Re:Physical InventoryThis e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.Maybe you guys can help me understand... Why do you need to perform a "Physical Inventory" in Epicor?As it relates to Epicor, isn't a physical inventory the same as a full cycle count with no movement?ScottOn Thu, Dec 19, 2013 at 10:52 AM, Len Hartka <len.hartka@...> wrote:Good Day Jacqueline:I do not think E9 can do that.You could just do a BAQ using PartQty file ( which list qty in each bin):Sort by bin#Paste in to ExcelPrint out (have page numbers to be sure you get them all back)Counters mark up the print out.Need to decide who and how to get the correction, since counters will count 487 and E9 = 349 correction =??? Plus or minus?)Keypunch adjustments into E9. ( or keypunch into Excell – calculate correction – SORT by Part# ( so Bin moves will be together) - keypunch correction into E9)Create a INV2014 reason code to use for easy reporting on total change.Watch out for Date-entered vs Date-transaction—count on 12/31/13, punch on 1/2/14 - affects G\L balances. That is, back-date the entry to 12/31.LenFrom: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jacqueline Restivo
Subject: Re: [Vantage] Re:Physical InventoryHi Jordan Thanks for the details of doing a physical inventory.Doing the steps you posted 0 out the existing inventory.We do NOT want to 0 out the inventory, only adjust inventory we have.Is this possible with Physical or only in cycle counting?thanksFrom: Jordan Klassen <jordan.k@...>
Subject: RE: [Vantage] Re:Physical InventoryPerforming a full physical inventory allows you to adjust the quantities when you enter the tags(Papers with the item counts on them after counting how much in stock.) If you would like I wrote up a procedure for performing full physical inventory. It was done for 9.05.700b, not sure how different that is from 606a.
Jordan
[Bully Dog Logo]<http://www.bullydog.com/>
Hi All,
Epicor 905.606A
thanks in advance
jacqueline
[Non-text portions of this message have been removed]This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-mkp #ygrps-yiv-938133045yiv4676318332hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-mkp #ygrps-yiv-938133045yiv4676318332ads {
margin-bottom:10px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-mkp .ygrps-yiv-938133045yiv4676318332ad {
padding:0 0;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-mkp .ygrps-yiv-938133045yiv4676318332ad p {
margin:0;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-mkp .ygrps-yiv-938133045yiv4676318332ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-sponsor #ygrps-yiv-938133045yiv4676318332ygrp-lc {
font-family:Arial;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-sponsor #ygrps-yiv-938133045yiv4676318332ygrp-lc #ygrps-yiv-938133045yiv4676318332hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-sponsor #ygrps-yiv-938133045yiv4676318332ygrp-lc .ygrps-yiv-938133045yiv4676318332ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332activity span {
font-weight:700;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332activity span span {
color:#ff7900;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332activity span .ygrps-yiv-938133045yiv4676318332underline {
text-decoration:underline;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 .ygrps-yiv-938133045yiv4676318332attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 .ygrps-yiv-938133045yiv4676318332attach div a {
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 .ygrps-yiv-938133045yiv4676318332attach img {
border:none;padding-right:5px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 .ygrps-yiv-938133045yiv4676318332attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 .ygrps-yiv-938133045yiv4676318332attach label a {
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 .ygrps-yiv-938133045yiv4676318332bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 .ygrps-yiv-938133045yiv4676318332bold a {
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 dd.ygrps-yiv-938133045yiv4676318332last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 dd.ygrps-yiv-938133045yiv4676318332last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 dd.ygrps-yiv-938133045yiv4676318332last p span.ygrps-yiv-938133045yiv4676318332yshortcuts {
margin-right:0;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 div.ygrps-yiv-938133045yiv4676318332attach-table div div a {
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 div.ygrps-yiv-938133045yiv4676318332attach-table {
width:400px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 div.ygrps-yiv-938133045yiv4676318332file-title a, #ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 div.ygrps-yiv-938133045yiv4676318332file-title a:active, #ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 div.ygrps-yiv-938133045yiv4676318332file-title a:hover, #ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 div.ygrps-yiv-938133045yiv4676318332file-title a:visited {
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 div.ygrps-yiv-938133045yiv4676318332photo-title a, #ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 div.ygrps-yiv-938133045yiv4676318332photo-title a:active, #ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 div.ygrps-yiv-938133045yiv4676318332photo-title a:hover, #ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 div.ygrps-yiv-938133045yiv4676318332photo-title a:visited {
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 div#ygrps-yiv-938133045yiv4676318332ygrp-mlmsg #ygrps-yiv-938133045yiv4676318332ygrp-msg p a span.ygrps-yiv-938133045yiv4676318332yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 .ygrps-yiv-938133045yiv4676318332green {
color:#628c2a;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 .ygrps-yiv-938133045yiv4676318332MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 o {
font-size:0;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332photos div {
float:left;width:72px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332reco-category {
font-size:77%;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332reco-desc {
font-size:77%;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 .ygrps-yiv-938133045yiv4676318332replbq {
margin:4px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-mlmsg select, #ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 input, #ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-mlmsg pre, #ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 code {
font:115% monospace;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-mlmsg #ygrps-yiv-938133045yiv4676318332logo {
padding-bottom:10px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-msg p#ygrps-yiv-938133045yiv4676318332attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-reco #ygrps-yiv-938133045yiv4676318332reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-sponsor #ygrps-yiv-938133045yiv4676318332ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-sponsor #ygrps-yiv-938133045yiv4676318332ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-sponsor #ygrps-yiv-938133045yiv4676318332ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-text {
font-family:Georgia;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-text tt {
font-size:120%;}
#ygrps-yiv-938133045 #ygrps-yiv-938133045yiv4676318332 #ygrps-yiv-938133045yiv4676318332ygrp-vital ul li:last-child {
border-right:none !important;}
Josh Serwe
Wisconsin Converting Inc.
Production Planning
(920)437-6400 x 327
Sent: Friday, December 20, 2013 2:09 PM
When you do a full cycle count do you have a variance report you can print or do you use the stock status as your baseline?
We've printed duplicate tags in the past, placed copies on the location, the other in the office to be entered. Is this still possible with cycle counting?
I'm developing a twitch just reminiscing about last 2 physical inventories.
Thanks and have a great weekend.
I could learn a thing or 2 from santa's elves, they keep a precise and mean inventory!
Jacqueline
Thanks Len,
I forgot about how many customizations we've built into barcode scanning and cycle counting. We can process about 10K lots in one day with one person.
We cycle count everything monthly which is why we never need to do a full physical inventory.
Scott
On Thu, Dec 19, 2013 at 12:40 PM, Len Hartka <len.hartka@...<mailto:len.hartka@...>> wrote:
Good Day Scott:
Merry Christmas,
&n bsp; Len
Len.hartka@...<mailto:Len.hartka@...>
Leonard C. Hartka
FAX: -329-3564
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>] On Behalf Of Scotty K.
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Scott
On Thu, Dec 19, 2013 at 10:52 AM, Len Hartka <len.hartka@...<mailto:len.hartka@...>> wrote:
Sort by bin#
Paste in to Excel
Len
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>] On Behalf Of Jacqueline Restivo
thanks
From: Jordan Klassen <jordan.k@...<mailto:jordan.k@...>>
To: "vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>>
Jordan
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com] On Behalf Of Jacqueline Restivo
Hi All,
Epicor 905.606A
thanks in advance
jacqueline
Sent: Friday, December 20, 2013 3:21 PM
Josh Serwe
Production Planning
(920)437-6400 x 327
Jacqueline
Thanks Len,
Scott
Good Day Scott:
Merry Christmas,
&n bsp; Len
Leonard C. Hartka
FAX: -329-3564
Scott
Sort by bin#
Paste in to Excel
Len
thanks
Jordan
Hi All,
Epicor 905.606A
thanks in advance
jacqueline
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-mkp hr {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-mkp #ygrps-yiv-684234329yiv8538157539hd {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-mkp #ygrps-yiv-684234329yiv8538157539ads {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-mkp .ygrps-yiv-684234329yiv8538157539ad {
padding:0 0;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-mkp .ygrps-yiv-684234329yiv8538157539ad p {
margin:0;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-mkp .ygrps-yiv-684234329yiv8538157539ad a {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-sponsor #ygrps-yiv-684234329yiv8538157539ygrp-lc {
font-family:Arial;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-sponsor #ygrps-yiv-684234329yiv8538157539ygrp-lc #ygrps-yiv-684234329yiv8538157539hd {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-sponsor #ygrps-yiv-684234329yiv8538157539ygrp-lc .ygrps-yiv-684234329yiv8538157539ad {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539actions {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539activity {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539activity span {
font-weight:700;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539activity span:first-child {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539activity span a {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539activity span span {
color:#ff7900;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539activity span .ygrps-yiv-684234329yiv8538157539underline {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 .ygrps-yiv-684234329yiv8538157539attach {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 .ygrps-yiv-684234329yiv8538157539attach div a {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 .ygrps-yiv-684234329yiv8538157539attach img {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 .ygrps-yiv-684234329yiv8538157539attach label {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 .ygrps-yiv-684234329yiv8538157539attach label a {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 .ygrps-yiv-684234329yiv8538157539bold {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 .ygrps-yiv-684234329yiv8538157539bold a {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 dd.ygrps-yiv-684234329yiv8538157539last p a {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 dd.ygrps-yiv-684234329yiv8538157539last p span {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 dd.ygrps-yiv-684234329yiv8538157539last p span.ygrps-yiv-684234329yiv8538157539yshortcuts {
margin-right:0;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 div.ygrps-yiv-684234329yiv8538157539attach-table div div a {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 div.ygrps-yiv-684234329yiv8538157539attach-table {
width:400px;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 div.ygrps-yiv-684234329yiv8538157539file-title a, #ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 div.ygrps-yiv-684234329yiv8538157539file-title a:active, #ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 div.ygrps-yiv-684234329yiv8538157539file-title a:hover, #ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 div.ygrps-yiv-684234329yiv8538157539file-title a:visited {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 div.ygrps-yiv-684234329yiv8538157539photo-title a, #ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 div.ygrps-yiv-684234329yiv8538157539photo-title a:active, #ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 div.ygrps-yiv-684234329yiv8538157539photo-title a:hover, #ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 div.ygrps-yiv-684234329yiv8538157539photo-title a:visited {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 div#ygrps-yiv-684234329yiv8538157539ygrp-mlmsg #ygrps-yiv-684234329yiv8538157539ygrp-msg p a span.ygrps-yiv-684234329yiv8538157539yshortcuts {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 .ygrps-yiv-684234329yiv8538157539green {
color:#628c2a;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 .ygrps-yiv-684234329yiv8538157539MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 o {
font-size:0;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539photos div {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539photos div div {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539photos div label {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539reco-category {
font-size:77%;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539reco-desc {
font-size:77%;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 .ygrps-yiv-684234329yiv8538157539replbq {
margin:4px;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-actbar div a:first-child {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-mlmsg {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-mlmsg table {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-mlmsg select, #ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 input, #ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 textarea {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-mlmsg pre, #ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 code {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-mlmsg * {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-mlmsg #ygrps-yiv-684234329yiv8538157539logo {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-msg p a {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-msg p#ygrps-yiv-684234329yiv8538157539attach-count span {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-reco #ygrps-yiv-684234329yiv8538157539reco-head {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-reco {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-sponsor #ygrps-yiv-684234329yiv8538157539ov li a {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-sponsor #ygrps-yiv-684234329yiv8538157539ov li {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-sponsor #ygrps-yiv-684234329yiv8538157539ov ul {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-text {
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-text tt {
font-size:120%;}
#ygrps-yiv-684234329 #ygrps-yiv-684234329yiv8538157539 #ygrps-yiv-684234329yiv8538157539ygrp-vital ul li:last-child {
On Fri, Dec 20, 2013 at 2:08 PM, Jacqueline Restivo <jacqueline_restivo@...> wrote:
Â<div> <p><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:12pt;"><div><span>When you do a full cycle count do you have a variance report you can print or do you use the stock status as your baseline? </span></div>
We've printed duplicate tags in the past, placed copies on the location, the other in the office to be entered. Is this still possible with cycle counting? I'm developing a twitch just reminiscing about last 2 physical inventories.ÂThanks and have a great weekend.ÂI could learn a thing or 2 from santa's elves, they keep a precise and mean inventory!ÂJacquelineFrom: Scotty K. <scottyk537@...>
ÂThanks Len,ÂI forgot about how many customizations we've built into barcode scanning and cycle counting. We can process about 10K lots in one day with one person.We cycle count everything monthly which is why we never need to do a full physical inventory.ÂScott
ÂGood Day Scott:           By “full cycle count with no movement†do you mean that you count all the parts in one day ( or a few days)?           If yes, then there is no real difference.           Cycle counting comes about when you have a lot of part#’s to count – I have 35,000 in stock at any time.           Since counting them all in one day ( a P.I.) is a MASSIVE and costly job, you go to cycle counting in order to do some each day.           Also, very importantly, you classify parts as ABC ( DEF?) based on usage-and-cost. You only count the cheap parts once a year or maybe once every few years. This saves a lot of money. You can do the cycle counts during slow days as a farther way to reduce cost.           Also, you count the A parts 3-4 times a year since these are the parts that must have a correct balance.           Final important idea is “What will the Auditors accept†– cycle counts have to be very well documented to make them happy; although, if you do it in one day, they would not care.           Of course there are also many considerations specific to your company. Are you counting diamonds or coal, do your parts get stolen, how good is your paperwork, do parts go bad, are you Santa Clause so you have a big ‘seasonal†problem.        Merry Christmas,          Â        &n bsp;        LenÂLeonard C. Hartka66 Loveton Circle, Sparks, MD, 21152Work: 410-329-3560 ext 120FAX: -329-3564Work Cell: 443-255-7192Personal Cell: 410-292-8744ÂÂÂÂÂFrom: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Scotty K.
Subject: Re: [Vantage] Re:Physical InventoryÂÂThis e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.Maybe you guys can help me understand... Why do you need to perform a "Physical Inventory" in Epicor?As it relates to Epicor, isn't a physical inventory the same as a full cycle count with no movement?ÂScottÂOn Thu, Dec 19, 2013 at 10:52 AM, Len Hartka <len.hartka@...> wrote:ÂGood Day Jacqueline:           I do not think E9 can do that.           You could just do a BAQ using PartQty file ( which list qty in each bin):                                   Sort by bin#                                   Paste in to Excel                                   Print out (have page numbers to be sure you get them all back)                                   Counters mark up the print out.                       Need to decide who and how to get the correction, since counters will count 487 and E9 = 349 correction =??? Plus or minus?)                                   Keypunch adjustments into E9. ( or keypunch into Excell – calculate correction – SORT by Part# ( so Bin moves will be together) -  keypunch correction into E9)           Create a INV2014 reason code to use for easy reporting on total change.           Watch out for Date-entered vs Date-transaction—count on 12/31/13, punch on 1/2/14 - affects G\L balances. That is, back-date the entry to 12/31.          Â        LenÂFrom: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jacqueline Restivo
Subject: Re: [Vantage] Re:Physical InventoryÂÂHi Jordan Thanks for the details of doing a physical inventory.ÂDoing the steps you posted 0 out the existing inventory.We do NOT want to 0 out the inventory, only adjust inventory we have.ÂIs this possible with Physical or only in cycle counting?thanksÂFrom: Jordan Klassen <jordan.k@...>
Subject: RE: [Vantage] Re:Physical InventoryÂÂPerforming a full physical inventory allows you to adjust the quantities when you enter the tags(Papers with the item counts on them after counting how much in stock.) If you would like I wrote up a procedure for performing full physical inventory. It was done for 9.05.700b, not sure how different that is from 606a.
Jordan
Hi All,
Epicor 905.606A
thanks in advance
jacqueline
[Non-text portions of this message have been removed]ÂThis e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.ÂThis e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.</div> <div style="color:rgb(255,255,255);min-height:0px;"></div>
