Scrap Material While Keeping Cost On The Job
I have a custom process that I brought from our previous system. In inspection processing if the scrap is ours and not a vendor defect the inspector can add the material at the bottom of the material list and then accept the bad material back to the job on the added material. This also make jobs gone wrong easy to spot in job tracker.
@utaylor , got it. I’m having flashbacks because we have had this conversation on the forum before. :laughing: :laughing:
I’m just going to be quiet now.
The Production Yield Recalc will only address your issue by lowering the Prod Qty on the Job where something was scrapped. With the loss of supply, theoretically it should create a new Job to make up the fall in supply. I don’t think this is what either of you are looking for. You are looking to have the system automatically create a material requirement when something is scrapped from a job.
Have either of you thought about using GL Control Codes to handle this? You could set the scrap context on the GLCC to point to the material account?
I love ya man, thank you for always engaging.
We are using this field here to scrap the materials to increase demand and keep cost on the job. I know this isn’t the intended functionality
This would be if we laser cut parts and we expect a scrap percentage of our raw materials. you can change from % to qty and use it for specific materials.
We are currently using the est % and recording scrap elsewhere.
If I think about where I would like to get, it would be some modified form that kicks off the “issue material to job” with set reason codes going into the reference.
Everyone has materials backflushing which is driving this need to add additional material used as scrap?
That’s the thing though, I wish the reason codes also counted it as scrapped and didn’t count it as issued material so that MRP and timephase still noted that more material was needed AND so that it would stay on the job.
What is your costing method?
We are avg on most parts. std on a select few like vmi/kanban.We don’t really hold inventory as most parts are very custom to a single project.
Okay, we hold raws and some semifinished goods so a little like you. We don’t use average, but either way you and I both want all costs on jobs so we can see just how much it costs… Who is your CAM by chance?
Is there anyone else out here in this forum that needs this functionality? I would get an idea posted and reach out to Epicor to see if we can’t band together and create a special interest group.
@TonyJagusch @jsmuland @gpayne
exactly this. We are going to build a custom screen into the issue material to try and help with this or something like that…
Emily A. is my CAM.
I created a Kinetic idea.
https://epicor-manufacturing.ideas.aha.io/ideas/KIN-I-5307
I keep running into on-the-fly job manipulation to be too cumbersome. Someone gathers the scrap number, opens the job up for editing, changes that number and releases it?
It’s almost like you would need duplicate lines at req qty 0 to issue the scrap to. We would be okay just over transacting as we don’t need to drive additional demand. The thought of double the BOM size just to add scrap layers also seems inefficient.
Right?? That’s way too much work to be doing and keep up with. The transactions that the operator makes should be invoking that change automatically, not us having to go back into the job and update it… but that’s what doesn’t exist, that’s the functionality we are missing.
That’s a great idea! wow. But yeah, duplicative.
Yeah and if we find the part that we scrapped because we lost it we have to go back and change the scrap to 0 and return it to inventory…definitely a very manual process that people have to remember to do.
This is where I get confused. I guess because I don’t have all of the requirements. I would just say over-transact then. If you just over-transact, all of the cost stays on the job. I know there is a piece I am not understanding, I just don’t know what it is.
You over transact because that’s the reality haha, you used too much material.
And you used too much material because A., you scrapped some finished product (at the end operation as you originally suggested) OR B., because you ruined some of material sequence XX when trying to run the job.
Now as you pointed out, scenario A still drives demand if you recalc yield, so we are good there, but scenario B, which happens in many industries I am sure, would show that you’ve already issued X amount even though you over issued because you scrapped some… Again, assuming we leave the scrapped amount on the job for costing purposes.
Ok, so when you review the job, you see that it cost x and took y more material.
Over transacting shows you the true cost and material usage. Still confused here.
I like this option the best, seems quickest to implement. You wait until the operation is complete and then accept all related inspections back in. With the right reason codes it could make sense to inspectors, built in double check basically requiring a sign off. Are you using inspection processing for other functions? What are the downsides you have?
