right…sorry, I updated my comment while you were entering yours. I am seeing what appears to be initial values returned for all the fields which are apparently setting the values, and it’s not putting the values I specify in.
That’s why a BPM (or BPMs) are probably going to be a better option. You have a little more control of when the value of set. If you find the method that is setting the value, then you can do a post processing on that method to change it to what you want.
In the case of the warehouse though, can you just change the primary warehouse on the part instead of customizing? (Assuming that is what is setting that field).
I moved this to it’s own topic because it really isn’t what the original thread was about.
