SSL Certs and Mobile CRM
Certificates for https connection must satisfy the folowing rules:
  1. The full domain name of the URL you are connecting to must be included in the certificate, either in Subject name (SN) or in Subject Alternative Name (SAN). So, if your cert contains www.company.com and you are trying to connect to www.company.net - this will fail. Same with subdomains - cert for www.company.com will not work for my.company.com, you have to use wildcard certificate for this - *.company.com in cert’s SN/SAN. This means that if your GoDaddy cert contains the domain name you are going to connect, then it will work. If you are going to use another domain - it won’t work.
  2. Client should trust the certificate. This is not a problem for certs issued by known authorities, like GoDaddy in you case. But for self-signed certs this will be a problem. You will have to export public key from you server cert into .cer file and import it on each client computer that is going to connect to your server. Import means that you place that .cer file into Trusted people or Trusted root folder of certificate storage for the client computer.
