Hi Prakash,
This could be an issue relating to upper/lower case. If you look in transaction history was the stock transferred to say bin 1ab1 where your master file bin is actually 1AB1?? if so the stock status report will ignore it. This has been fixed in 10.2…we upgraded from 10.1.600.16 to fix this issue.
Apparently Epicor have fixed certain reports/programs in different versions but all of the case related issue have been fixed in 10.2. We were told by Epicor that we either needed to implement some BPM to ensure capitals were used and run a sql script provided to convert the data.
Hope this helps,
Cheers
Paul
