Here’s the full Application Error
Application Error
Error Detail
Message: An error occurred while reading from the store provider’s data reader. See the inner exception for details.
Inner Exception Message: Lock request time out period exceeded.
Program: Epicor.ServiceModel.dll
Method: ShouldRethrowNonRetryableException
Client Stack Trace
at System.Data.Common.Internal.Materialization.Shaper
1.StoreRead() at System.Data.Common.Internal.Materialization.Shaper1.SimpleEnumerator.MoveNext()
at System.Collections.Generic.List1..ctor(IEnumerable1 collection)
at System.Linq.Enumerable.ToList[TSource](IEnumerable1 source) at Epicor.Data.DBExpressionCompiler.GetResult[TContext,TQuery,TResult](Func3 executeQuery, Cache cacheSetting, TContext dataContext, TQuery query) in C:_Releases\ICE\3.1.500.22\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 425
at Epicor.Data.DBExpressionCompiler.InvokeList[TContext,TQuery,TResult](Expression expression, Cache currentCacheSetting, Boolean cacheQuery, TContext dataContext, Func2 getDataCacheKey, Func2 compileQuery, Func3 executeQuery) in C:\_Releases\ICE\3.1.500.22\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 159 at Epicor.Data.DBExpressionCompiler.<>c__DisplayClass2_04.b__0(TContext context, TArg1 arg1, TArg2 arg2) in C:_Releases\ICE\3.1.500.22\Source\Framework\Epicor.System\Data\DBExpressionCompiler.Generated.cs:line 82
at Erp.Internal.Lib.JobHeadDelete._JobHeadDelete(JobHead JobHead) in c:_Releases\ERP\RL10.1.500\Source\Server\Internal\Lib\JobHeadShared\JobHeadDelete\delete.i.cs:line 196
at Erp.Triggers.JobHead.DeleteTrigger.delete(JobHead JobHead) in C:_Releases\ERP\UD10.1.500.22\Source\Server\Db\Triggers\JobHead\delete.cs:line 73
at Erp.Triggers.JobHead.DeleteTrigger.Delete(JobHead JobHead) in C:_Releases\ERP\UD10.1.500.22\Source\Server\Db\Triggers\JobHead\delete.cs:line 64
at Ice.Triggers.TriggerQueue.ExecuteDeleteTrigger(IceDataContext context, LinqRow originalRecord) in C:_Releases\ICE\3.1.500.22\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 259
at Ice.Triggers.TriggerQueue.RunDeleteTrigger(IceDataContext context, LinqRow linqRow) in C:_Releases\ICE\3.1.500.22\Source\Framework\Epicor.System\Triggers\TriggerQueue.cs:line 124
at Ice.IceDataContext.DeleteObject(Object entity) in C:_Releases\ICE\3.1.500.22\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 210
at Ice.TablesetBound3.DeleteRow(IceDataContext dataContext, String tableName, LinqRow dbRow, TablesetProfilingCollector parentTraceCollector) in C:\_Releases\ICE\3.1.500.22\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1257 at Ice.TablesetBound3.DeleteRow(IceDataContext dc, Int32 tableNum, IIceTable tbl, IceRow row, TablesetProfilingCollector parentTraceCollector) in C:_Releases\ICE\3.1.500.22\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 1229
at Ice.TablesetBound3.WriteTable(IceDataContext dataContext, Int32 tableIndex, IIceTable table, TablesetProfilingCollector parentTraceCollector) in C:\_Releases\ICE\3.1.500.22\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 906 at Ice.TablesetBound3.InnerUpdate(IceDataContext dataContext, TFullTableset tableset) in C:_Releases\ICE\3.1.500.22\Source\Framework\Epicor.Ice\Services\TablesetBound.cs:line 797
at Erp.Services.BO.JobEntrySvc.Update(JobEntryTableset& ds) in C:_Releases\ERP\UD10.1.500.22\Source\Server\Services\BO\JobEntry\JobEntry.Designer.cs:line 7392
at Erp.Services.BO.JobEntrySvcFacade.Update(JobEntryTableset& ds) in C:_Releases\ERP\UD10.1.500.22\Source\Server\Services\BO\JobEntry\JobEntrySvcFacade.cs:line 4049
at SyncInvokeUpdate(Object , Object , Object )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object inputs, Object& outputs)
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func2 func) in C:\_Releases\ICE\3.1.500.22\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59 at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func2 func) in C:_Releases\ICE\3.1.500.22\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 47
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object inputs, Object& outputs) in C:_Releases\ICE\3.1.500.22\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
Inner Trace:
: at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlDataReader.TryHasMoreRows(Boolean& moreRows) at System.Data.SqlClient.SqlDataReader.TryReadInternal(Boolean setTimeout, Boolean& more) at System.Data.SqlClient.SqlDataReader.Read() at System.Data.Common.Internal.Materialization.Shaper1.StoreRead()
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet dataSets)
at Erp.Proxy.BO.JobEntryImpl.Update(JobEntryDataSet ds)
at Erp.Adapters.JobEntryAdapter.OnDelete()
at Ice.Lib.Framework.EpiBaseAdapter.Delete(DataRow dr)
at Erp.UI.App.JobEntry.Transaction.Delete()
Inner Exception
