Zero Balance A/P Invoice
Assuming ValueDate is a date try this:
iif(PromDate < 2/28/01, PromDate, iif(inv >= QtyDue, today(),
03/01/01))
If ValueDate could be yes/no then the formula is:
iif(PromDate < 2/28/01, yes, iif(inv >= QtyDue, yes, no))
You could use that field to control whether a line would print or not.
HTH
RRD
On 9 Feb 2001, at 15:10, chuck_metcalf@... wrote:
I need help on a formula: My data looks like this;
PromDate Part# ProdQty QtyDue Inv
Value
2/9/01 12345 7 6 0
? 23456 0 5 15
3/1/01 45678 8 7 0
? 56789 0 8 10
I would like the value "Calculated Field in my report
is ValueDate"
to show up if the PromDate is before 2/28/01, or if
the unknown value
is in the PromDate, but there is enough inventory to
support the
QtyDue.
Any help would be appreciated.
Chuck
Russ Dover
IS Manager
Weaver Industries, Inc.
717 336 7507 phone
717 336 4182 fax
rdover@...
www.weaverind.com
Russ,
Thank You for your response. The valuedate is actually the $value of the qty
due.
Chuck
Sent: Friday, February 09, 2001 9:52 AM
Subject: Re: [Vantage] Report Builder
03/01/01))
HTH
RRD
Value
2/9/01 12345 7 6 0
? 23456 0 5 15
3/1/01 45678 8 7 0
? 56789 0 8 10
is ValueDate"
the unknown value
support the
QtyDue.
Chuck
Russ Dover
IS Manager
717 336 7507 phone
717 336 4182 fax
rdover@...
www.weaverind.com
To unsubscribe from this group, send an email to:
vantage-unsubscribe@egroups.com
Does anyone have a report that will identify manufactured parts that
do not have methods available to pull into jobs.
Chuck
Is there anyway using Report Builder that you can tell if methods for
a part number have been approved.
Chuck
The easiest thing is to run a report that will show only those manufactured
parts that have no labor costs.
Greg Clauser
Lakin General Corp.
Sent: Tuesday, February 13, 2001 8:36 AM
Subject: [Vantage] Report Builder
Chuck
Use the PartBOM table, filter for approved = Yes. That's about the only way
I can think of doing it, but I'm sure there must be some others.
Check the data dictionary to see if any other of the part tables list
"approved".
Lydia
Sent: Tuesday, February 13, 2001 9:48 AM
Chuck
PartBOM is just a temp table. You'd have to start with partrev.
> "approved".
> Lydia
> From: chuck_metcalf@... [mailto:chuck_metcalf@...]
> Thanks
> Chuck
Absolutely correct. Didn't mean to steer anybody down the wrong path.
Lydia
Sent: Tuesday, February 13, 2001 1:36 PM
way
In a logical field when the results are Yes, No, ?, how can I pick up
the records that are No and ?. The unknown is because no data has
been entered into the field.
Chuck
Field <> true
-WC
if result <> YES or
if result = NO or result = ?
Hope this helps.
Tim Care
Electro Chemical Finishing
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Monday, February 26, 2001 11:37 AM
> Thanks
> Chuck
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Thank You for your quick response, but it doesn't seem to work. I am working
with PartRev.Approved. If the field is blank, nothing shows up. Any other
ideas.
Chuck
if result <> YES or
Hope this helps.
> Thanks
> Chuck
Chuck,
Try creating a calculated field PR-Apr = IIF(partrev.approved =
?,No,partrev.approved)
Then filter on PR-Apr. The calc would force all unkown values to be a
logical NO while leaving all other values as is.
Todd Anderson
Sent: Monday, February 26, 2001 11:26 AM
Subject: RE: [Vantage] Report Builder
ideas.
Chuck
if result <> YES or
Hope this helps.
> Thanks
> Chuck
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=140160.1334960.2924124.2/D=egroupmail/S=1700007183:N/
A=488695/?http://www.optionetics.com/free_tym.asp> Become a Better Trader!
<http://us.adserver.yahoo.com/l?M=140160.1334960.2924124.2/D=egroupmail/S=17
00007183:N/A=488695/rand=886884757>
Is there a way to search a string of text and only have the lines on
a report that have certain text.
Chuck
I have done this several times using SUBSTRING, INDEX and other functions to
set a logical and then test the logical on a conditioned line. You can have
several conditioned lines in the same group. I have also done this within a
line and set two calculated string fields to either be a value or spaces and
then place them on top of each other so that only the "true" one overprints
the spaces from the other. Handy for conditional bolding or color (red =
negative). Hope one of these are what you were looking for.
-Todd C.
Sent: Wednesday, February 28, 2001 11:27 AM
Chuck
<http://rd.yahoo.com/M=179201.1342935.2933264.2/D=egroupmail/S=1700007183:N/
A=585621/*http://www.egghead.com/category/inv/00000870/03597619.htm?mid=yaho
o_cga153_cs> At Egghead.com...We Mean Business!
<http://us.adserver.yahoo.com/l?M=179201.1342935.2933264.2/D=egroupmail/S=17
00007183:N/A=585621/rand=602854443>
How are you doing conditional bolding or color in Report Builder?
> -Todd C.
> Thanks
> Chuck
RB, I noticed one time, allows printing fields over the top of each other.
Often by error and it looks very garbled. If I have a condition I want to
test for and print boldly I create a logical (perhaps PrintBold) and set it
to True. I can then create two calculated string fields for IIF(PrintBold
= True,STRING(value,'-format-'.' ') and the opposite IIF(PrintBold <>
True,STRING(value,'-format-'.' ') I then call one PrtValueBold and the
other PrtValueReg. On the report I format the bold one as bold and place
both fields on top of each other. It makes it a little hard to get decimals
to line up and to see one or the other but only one will print anything and
it will print over spaces (the other field). On the final report you can't
see the spaces even if they are bold :) so it looks OK. Ditto for font
colors instead of (or with) bold. On screen or on color printing this looks
really sharp for pointing out particular data.
-Todd C.
Sent: Wednesday, February 28, 2001 12:05 PM
to
have
a
and
overprints
> -Todd C.
> Thanks
> Chuck
> A=585621/*
<http://www.egghead.com/category/inv/00000870/03597619.htm?mid=yaho>
> < http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
<http://rd.yahoo.com/M=162801.1342103.2934627.1280005/D=egroupmail/S=1700007
183:N/A=599088/*http://www.knowledgestorm.com/jump_white.html?c=Yahoo&n=eLer
t_ComputersInternet_Software_WhiteGridTime&t=ad> Click Here to Find Software
Faster
Click Here to Find Software Faster
<http://us.adserver.yahoo.com/l?M=162801.1342103.2934627.1280005/D=egroupmai
l/S=1700007183:N/A=599088/rand=879900813>
Todd,
I have not had any success in making this formula. This is a typical text
line that I am dealing with.
Tractor MATERIAL: 2024-T42-0063-C F-17.26 + F-20.03 PER MilStd.
CERTIFICATIONS REQUIRED. THANK YOU.
I would like only the text lines that have F-17.26 to print and the info is
randomly spaced.
Chuck
-Todd C.
Chuck
1. I loaded the whole message into TestValue (a caluclated field)
2. I created another calculated field: TestPositive:
IIF(INDEX(TestValue,'F-17.26',1) > 0,Yes,No)
Note you could load the string searched for into its own field to make
formula more universal
Such as: IIF(INDEX(TestValue,SearchFor,1) > 0,Yes,No)
3. Create a BandLine in a group, insert what you need into it (fields, text,
etc...)
4. Right click on bandline margin at far left edge to get to bandline
properties (there are other ways too)
5. In properties check mark Print Conditional Field and enter TestPositive
in it and select "Print When Field True"
This will print that line only when the TestValue string has 'F-17.26'
anywhere in it. I use the same test to check for jobs we set up with a T or
C in the ID (tooling jobs) and the SO group is not Engineering - I then
print a warning line on certain reports.
Good luck,
-Todd C.
Sent: Thursday, March 01, 2001 7:33 AM
Todd,
randomly spaced.
Chuck
-Todd C.
Chuck
183:N/A=599089/*http://www.knowledgestorm.com/jump_white.html?c=Yahoo&n=eLer
t_ComputersInternet_Software_WhiteGridOptions&t=ad> Click Here to Find
Software Faster
l/S=1700007183:N/A=599089/rand=165901064>
Charles,
Try this: create a calculated field called something like PrintThis using
this formula:
IIF(LOOKUP("F-17.26",Part.Description," ") > 0, True, False)
and then set conditional printing to print when PrintThis = True.
Hope this helps.
Steve Sanders
Delta Centrifugal Corp.
Todd,
text
is
randomly spaced.
Chuck
to
have
a
and
overprints
-Todd C.
Chuck
