Joshua,
Thanks very much for the SQL trigger code - a simple but brilliant fix!! We’re having this issue after upgrading to 2022.x recently.
Good to know that it is not an issue with the kinetic MES screens though! We’re in the process of migrating to the kinetic MES, but are working past some barcoding issues there before we can make that leap.
No problem. Only need to use that if you want to extend beyond 3 days. If it wasn’t a problem previously for you then I would advise just setting the timeout back to 3 days in the app server application settings.
