2026.1: My kinetic custom apps have a lot of errors related with grids
This is just one example but since the update in our test environment, I noticed that a lot of apps doesn’t work anymore because of that. Some works which is weird but most of them are broken right now
Error 1: I have a column changed event on some column of the grid and it doesn’t trigger anymore
2025.1:
2026.1:
Nothing new in debug mode:
Error 2: I have a data rule to put a color in the cells of the updateable columns but it’s now blank
2025.2:
2026.1:
Any idea what the cause might be ? I tried to delete every single thing from my layer one by one but it doesn’t fix anything. I thought there was a wrong value in a property or something…And in the browser console, I have some errors but I had the exact same errors in my 2025.2 environment and that one works so no reason for it to cause any issue
Do you get these errors on base as well? Thought those errors were normal. Something to do with timeouts. but the layer requests again and you see the first errors.
There’s nothing in my base app. I built it from scratch a year or two ago but only by creating a layer (There’s only 1 layer activated at a time)
There in lies the rub, the Kinetic version of a year or two ago is DRASTICALLY different from 2026
Can you upload one of your broken layers, we may be able to spot a pattern that is easy to fix across the board.
Trying to find an application that I can easily share and replicate because for now, most of the ones with problems are the big ones with a lot of dependancies and I don’t necessarily want to share these complex dashboards ! Will let you know if I find one or I will just create a new layer from that app and remove all the things we don’t need to see the problem
Just to follow up on this. I talked to one of our partner and they found a way to replicate the issue in a Training environment. It was reported as a PRB recently (PRB0325845) but it’s about the Row Changed event and not Column Changed
Will try to use this to open other related problems because I have a few to fix. Thanks for your help, at least I know now that’s it’s a much bigger update that we are used to
