2026.104 Dashboards Broken
After the 2026.104 update on our non-production environments, we’re seeing custom dashboards are broken on those environments. Trying to load them to redeploy from Application Studio also fails to load anything. Anyone else seeing this issue?
We’re seeing the same error.
:man_facepalming:
Support gave me this explanation:
They offered to implement a fix to “remove the unnecessary tenancy stamping” but we never got that fix from what I can tell.
We fixed this ourselves by reinstalling the original solution file we created when we made the custom applications.
My case for this issue was linked to PRB0323815.
I’ll ask to have our ticket linked to the PRB.
Trash Garbage GIF by 100% Soft
Not a solution but I exported the dashboard from PROD 2026.100.9 and imported into PILOT. It still wouldn’t work until I opened the layer in AppStudio and waited for it to load into the designer (which took a few minutes) then it started working.
:man_shrugging:
Same issue over here–linked to PRB0323815 and was fixed after running supplied hotfix.
It looks like the hotfix was removed from my ticket, but I think it was CR3918SYD_2026_104_SQL
(hard to remember which hotfix it was due to all the hotfixes we’ve had in the last few weeks)
For those who are missing dashboards without viable backups, all may not be lost. You can enter an EpicCare ticket and provide the Application ID to Epicor who may be able to provide a fix to recover your data. Adding this disclaimer that cloud environments may be different and your mileage may vary, but I’ve checked four separate cloud customers today who all had the same issue and resolution.
You will not see XXXDef records in cross-company BAQs because the tenancy stamps in the CompanyID field are excluding them from your vision. However, these records are still present in the data model. By iterating through the tenant-specific records in XXXDef, the Epicor data fix will clear the CompanyID field if there is not a pre-existing tenant-independent record for types KNTCUDApp and KNTCMetaUI entries for your Ice.UIDbd.YourDashboardHere. The practical shortcut for Epicor’s data fix might be something similar to this if they wrote it as a function with a string parameter appID and a single updatable table reference to XXXDef, which is shown here for informational purposes only.
foreach(var xxxDef in Db.XXXDef.Where(x => x.Key1 == appID && x.Company != String.Empty).ToList())
  bool destinationExists = Db.XXXDef.Where(x => x.Company == String.Empty && x.ProductID == xxxDef.ProductID && x.Key1 == xxxDef.Key1 && x.Key2 == xxxDef.Key2 && x.Key3 == xxxDef.Key3).Any();
  if(!destinationExists)
    xxxDef.Company = String.Empty;
Db.SaveChanges();
To Epicor’s credit here, after the XXXDef records are visible again, the first call to Ice.LIB.MetaFXSvc/GetApp via launching the menu item will automatically recompile the dashboard after approximately 2 minutes and present as normal. There is no need to republish via application studio.
Ah, glad it is not just me then!
Our Live is on 100.9 and Pilot on 104, the dashboards in App studio seem broken in Pilot.
I was going through them individually and exporting Base and Layer from Live then importing into Pilot which seems to fix but it is a faff when you have loads of them.
Reimporting my saved Solution did not work.
I asked about this on the ticket, btu they said it needed more testing and hasn’t been released yet. Which seems kind of ridiculous since it’s the testing environment that’s broken, but… :thinking:
Can you escalate the ticket?
Will be doing that if I don’t get an update this morning!
I got an update today on my ticket that Dev has a stable “hotfix container” to resolve the issue. They are going to apply it to our PILOT. Waiting until they’re done to test it out.
I also got that update. Waiting on THIRD to have the hotfix applied now, will report back as well!
Did anybody get to try the hotfix yet? Did it work?
Just checked, it looks like dashboards are functioning again on both our non-prod environments!
How were you able to get them working? Was it the hotfix? We have several dashboards in our Pilot that have not worked since an update to 2026.104.0.
You’ll need to submit a ticket and request the hotfix.
We’ve submitted a ticket. I need to check if the hotfix has been installed.
Yeah they applied the hotfix for us. It’s an aaaabsolute cluster. Things may be still broken, only broken in one env and not another, or outright disappeared. We’re creating a running list and scrambling to find working app versions for everything built.
Hopefully for all we are just having super bad luck.
