4GL code to create an info message box
I got it to work.  There needs to be a space between the "i' and the  "&" symbol. Thanks for your help.
Â
Dustin Biniek
Sent: Tue, April 20, 2010 12:08:21 PM
Subject: RE: [Vantage] 4GL code to create an info message box
Â
{lib/PublishInfoMsg .i &InfoMsg = "'Message.'" }
You will have to define what the message variable is equal to before you
get a message. In your example, test = "This is a test.".
Tim Dines
Information Technology
Steel Parts Manufacturing, Inc.
801 Berryman Pike
Tipton, IN 46072
Direct: 765-675-5201
Cell: 765-437-1402
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of melissa hietala
Sent: Tuesday, April 20, 2010 12:53 PM
To: vantage@yahoogroups .com
Subject: [Vantage] 4GL code to create an info message box
Can someone please give me the correct code to launch an info message
box in 4GL code? I had thought it was the following:
{lib/PublishInfoMsg .i&InfoMsg = "Test.'"}.
but this errors out on me saying: "lib\PublishInfo Msg.iInfoMsg" was
not found. Could not understand line 7.
Any ideas?
Dustin Biniek
Can someone please give me the correct code to launch an info message box in 4GL code? I had thought it was the following:
{lib/PublishInfoMsg.i&InfoMsg = "Test.'"}.
but this errors out on me saying: "lib\PublishInfo Msg.iInfoMsg" was not found. Could not understand line 7.
Any ideas?
Â
Dustin Biniek
I had the same problem yesterday . I checked the location of the file and is in the server/lib so I dont understand why this won't work in a BPM.
> Any ideas?
> Thanks,
> Â
> Dustin Biniek
{lib/PublishInfoMsg.i &InfoMsg = "'Message.'"}
Tim Dines
801 Berryman Pike
Tipton, IN 46072
Cell: 765-437-1402
Of melissa hietala
Any ideas?
Dustin Biniek
Hi Dustin,
If you want to display text, you have to put it inside singles quotes and then inside double quotes: "'Test.'"
To display the contents of a field, just use double quotes.
HTH,
Nigel.
> Any ideas?
> Thanks,
> Â
> Dustin Biniek
