4GL error when connecting to Database
I am getting a "Warning" each time I try to connect to the Database when creating a 4GL program in the Procedure Editor on Windows XP Pro.
Warning One: **BUTTON btn_Options does not fit in parent DIALOG-BOX Connect. (6491)
Warning Two: **BUTTON btn_Help does not fit in parent DIALOG-BOX Connect. (6491)
After clicking OK past the two warnings, I can then enter the database options to connect.
This does not happen on my Windows 2000 box. Both of these are Stand Alone installs of Vantage. The WinXP Pro is a new install.
I connect by right-clicking in the Procedure Editor, selecting Insert / Database Fields.
Any idea where the errors are coming from?
Troy Funte
Liberty Electronics
