Excellent...thanks.
Of Stephen Edginton
Sent: Tuesday, July 22, 2008 10:50 AM
Subject: RE: [Vantage] 4GL Stop Error in new Configurator (8.03.305)
Check the appservers logs for the actual error.
Behalf
Of rapat_mark
Sent: 22 July 2008 16:44
Subject: [Vantage] 4GL Stop Error in new Configurator (8.03.305)
I am working on my first Configurator and am getting the below error.
After selecting the motor horsepower the user selects either Class I,
Class II, or Class III for the drive type from a combo box. Upon
existing that field it runs one of 3 .p programs depending on which
class they picked. This returns the appropriate size drive package.
Whenever I click on Class III I get the following error:
Error Detail
4GL STOP condition: The Server application has returned an error.
(7243) (7241)
Stack Trace
at Epicor.Mfg.UI.Adapters.ConfigurationAdapter.ApplyLeave(String
partNum, String revisionNum, Int32 pageNum, String inputName, String
testMode, Int32 mtlSeq, ConfigurationValueDataSet ds)
at
Epicor.Mfg.UI.App.ConfigurationEntry.Transaction.ApplyLeaveTrigger(Strin
g
columnName)
at
Epicor.Mfg.UI.App.ConfigurationEntry.Transaction.ProcessColumnChanged(Ob
ject
sender, DataColumnChangeEventArgs e)
at System.Data.DataColumnChangeEventHandler.Invoke(Object sender,
at System.Data.DataTable.OnColumnChanged(DataColumnChangeEventArgs e)
at System.Data.DataRow.set_Item(DataColumn column, Object value)
at System.Data.DataRowView.SetColumnValue(DataColumn column, Object
value)
at System.Data.DataRowView.set_Item(String property, Object value)
at Epicor.Mfg.UI.FrameWork.EpiUltraCombo.updateDataSource(Object
sender, Boolean forceUpdate)
Of Stephen Edginton
Behalf
Of rapat_mark
Error Detail
(7243) (7241)
Stack Trace
at
g
columnName)
at
ject
value)
