I wonder if there are any Part or PartPlant records without a valid
PROGRESS_RECID or PROGRESS_RECID_IDENT_ column. If there was one, you
might try deleting it by hand from SQL Management Studio.
-bws
Of kkearnscirmi
Sent: Wednesday, October 27, 2010 10:06 AM
Subject: [Vantage] Re: 4GL Stop Error When Adding new Part
Unfortunately the log file is not very helpful
If you have any ideas, please let me know.
- (Procedure: 'as/activate.p' Line:380) Incoming call from TMR-03:0
TRACE: SINGLE-RUN Procedure bo/ReportMonitor.p:GetRowsKeepIdleTime START
(8458)
TRACE: SINGLE-RUN Procedure END SUCCESS. (8458)
Unknown data source error. (6159)
** 4GL Debug-Alert Stack Trace **
ttPartPlantRefresh bo/Part.p (D:\epicor\mfgsys803\Server\bo\Part.r) at
line 81895
partAfterUpdate bo/Part.p (D:\epicor\mfgsys803\Server\bo\Part.r) at line
64365
PartCreateRow bo/Part.p (D:\epicor\mfgsys803\Server\bo\Part.r) at line
9162
PartUpdate bo/Part.p (D:\epicor\mfgsys803\Server\bo\Part.r) at line 9349
Update bo/Part.p (D:\epicor\mfgsys803\Server\bo\Part.r) at line 44313
Tried to access a record without a valid id. (6167)
--- In vantage@yahoogroups.com, "Brian W. Spolarich" <bspolarich@...>
wrote:
-bws
Of kkearnscirmi
(8458)
line 81895
64365
9162
wrote:
>Behalf
> Go and look at the MfgSys803.server.log file. There should be some
> messages there that probably bubbled up from MSSQL telling you what's
> wrong.
> -bws
> Of kkearnscirmito
> Sent: Wednesday, October 27, 2010 9:51 AM
> Subject: [Vantage] 4GL Stop Error When Adding new Part
> We are experiencing a 4 GL Stop error when we attempt to add new part
> the system. We think the problem started when we experienced a failedonly
> insert of a part into the part and partplant tables. The data was
> added to the part table. We have backed up the SQL database and the(7243)
> Progress database and restored over Test.
> We ran the data conversion processes from the admin tools but that did
> not help. We are on 8.04.405b SQL
> Error message
> Error Detail
> 4GL STOP condition: The Server application has returned an error.
> (7241)requestID,
> Stack Trace
> at Progress.Open4GL.DynamicAPI.Session.runProcedure(String
> String procedureName, ParameterSet parms, Boolean persistent, BooleanProgress.Open4GL.DynamicAPI.PersistentProc.runTheProcedure(String
> internal_Renamed, Int64 procId, MetaSchema localSchema, Int32
> stateModel)
> at Progress.Open4GL.DynamicAPI.Session.runStatelessProcedure(String
> requestID, String fullProcedureName, ParameterSet inparams, Object
> procId, MetaSchema localSchema, Int32 stateModel)
> at
> requestID, String procedureName, ParameterSet parms, MetaSchemaschema)
> at Progress.Open4GL.DynamicAPI.PersistentProc.runProcedure(String)
> procedureName, ParameterSet parms, MetaSchema schema)
> at Epicor.Mfg.Proxy.PartImpl.Update(PartDataSet ds)
> at Epicor.Mfg.UI.Adapters.PartAdapter.Update()
> at Epicor.Mfg.UI.App.PartEntry.PartTransaction.AdapterUpdate()
> at Epicor.Mfg.UI.App.PartEntry.PartTransaction.UpdateX()
> Any suggestions or ideas would be greatly appreciated.
> Thanks
> (1) To access the Files Section of our Yahoo!Group for Report Builder------------------------------------
